Can I use 4 output on stage?
fg65082001
Hey guys
I have a question that confused me for a long time
I don't have any stereo effect in my chain, all effect is mono.
So, I am using direct out mode XLR L out to PA Mixer
And XLR R to a IEM system for myself and other members to listen
to ensure my best guitar sound.
and I also want to use my 1/4 out L to plug in the Amp/Cab Return as a ampflier (NOT for F.O.H.)
Because I want to give the front part of audience just listen only Drums (if we don't use Amp/Cab anymore)
But i heard that there is a problem that it will cause the gear break becuz of the "Ground" will be the same between 1/4 and XLR output
and it will make "Electricity backfeeding" damage the console and POD HD!
REALLY?
Can I use 3 output or even 4 output at the same time?
Can Someone help me to solve my confusion, and tell me if there's other problem not include?
Thx a lot!
The unit is not grounded thru the power supply connector (yes, there are only 2 contacts there). It is grounded thru the input/output analog (1/4", XLR) and digital (USB, SPDIF) signal connectors. I don't think you'l blow anything up unless your venue has faulty wiring between the PA mixer, IEM system, and FOH amp. The grounds for those 3 systems should be referenced to the same point (usually the fuse box in the US).
