Sign in to follow this
Followers
0
New Helix amp models and topology on the DT25
By
scotty_burford, in DT50 / DT25
CraigGT 48
I tend to just leave mine on class A, pentode, topo 3 and let the Helix do the work nowadays.
Craig
Thanks Craig
sminchk67 69
Any idea how to make the Helix change channels on the DT-25?
Thanks,
Scott.
MartinDorr 80
I have not used this but I believe you connect Midi from Helix to DT25 and the use a template tone as a start to drive Midi signals to the DT for channel switching as you select the tone config added to the template. sorry, do not know more, but I have seen the template before and posts on the Helix forum describing some details. probably worth searching and then asking about what troubles you run into when trying.
Followers
0
Hi there
I was wondering if anyone who is using the Helix with the DT25 had any advice on selecting the best topology from one of the new Helix amps, such as the Litigator?
Thank you
