LutherDeLorme Posted June 3, 2017 Share Posted June 3, 2017 I have the Helix LT for almost a week now, and I am tweaking parameters a lot. Constantly manually setting the controller to 'snapshot'. I am thinking : my workflow would really benefit when all the controllers of all parameters by default have the value 'snapshot'. Is that possible? The default value now is 'none'. EDIT: hmmm...I read in the manual that each preset can have maximum of 64 controlller assignments. So that can be a problem. Hmm....but perhaps someone knows a trick to fastly assign multiple controllers to the value 'snapshot' ......but I guess not.....the maximum of 64 is a problem.....now, if anyone has some thoughts about it, happy to hear it. Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted June 3, 2017 Share Posted June 3, 2017 I'm not sure I understand why it's necessary to set the controller to snapshot if your tweaking parameters a lot. That sounds more like you're just adjusting a preset. Snapshots are only really meant for complex or detailed mass changes in a preset. Or am I missing something? Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 3, 2017 Share Posted June 3, 2017 On the unit itself, you just press and turn the knob underneath the parameter to assign it to a snapshot controller. In the editor, it's very fast as well. The shortcuts are: - Snapshot Assign Shortcut—OPTION-click (Mac) or ALT-click (PC) any Home screen parameter to quickly assign its value to the Snapshots controller - Unassign Controller Shortcut—SHIFT-OPTION-click (Mac) or SHIFT-ALT-click (PC) any Home screen parameter to instantly remove any controller assignment Quote Link to comment Share on other sites More sharing options...
LutherDeLorme Posted June 3, 2017 Author Share Posted June 3, 2017 I'm not sure I understand why it's necessary to set the controller to snapshot if your tweaking parameters a lot. That sounds more like you're just adjusting a preset. Snapshots are only really meant for complex or detailed mass changes in a preset. Or am I missing something?Well, I like to make snapshots where the parameters of the same effect/amp have different values from one snapshot to the other. For instance: set the drive of the amp at a higher level in snapshot 2, or set the mix of a delay at a higher level. You need to set the controller of that parameter to 'snapshot' or else when you change a paramater that change will be for every snapshot in a preset. With setting the controller to 'snapshot' you can set a unique value for that parameter in a particular snapshot.I don't know if you knew this already, but if you did knew this then I don't understand what you don't understand about my post :) So I am not adjusting presets, I am adjusting snapshots within a preset. And I do that a lot, so I am looking for ways to make my workflow faster. Quote Link to comment Share on other sites More sharing options...
LutherDeLorme Posted June 3, 2017 Author Share Posted June 3, 2017 On the unit itself, you just press and turn the knob underneath the parameter to assign it to a snapshot controller. In the editor, it's very fast as well. The shortcuts are: - Snapshot Assign Shortcut—OPTION-click (Mac) or ALT-click (PC) any Home screen parameter to quickly assign its value to the Snapshots controller - Unassign Controller Shortcut—SHIFT-OPTION-click (Mac) or SHIFT-ALT-click (PC) any Home screen parameter to instantly remove any controller assignment Thanks for your reply :) I know the procedure on the unit itself, but I didn't knew it in the editor. I will look into it, thanks. Quote Link to comment Share on other sites More sharing options...
zooey Posted June 3, 2017 Share Posted June 3, 2017 It's pretty quick in general I think, but you can absolutely safe a copy of a preset, then swap out the amp and/or cab, and maybe some of the FX. Thing is though, when you change blocks, like to a different amp or cab for instance, all those assignment go away. Quote Link to comment Share on other sites More sharing options...
LutherDeLorme Posted June 3, 2017 Author Share Posted June 3, 2017 It's pretty quick in general I think, but you can absolutely safe a copy of a preset, then swap out the amp and/or cab, and maybe some of the FX. Thing is though, when you change blocks, like to a different amp or cab for instance, all those assignment go away. You mean that perhaps it is faster to copy a preset several times and start tweaking every preset. And work less with snapshots? Thats an idea indeed! I then don't have the problem of constantly having to set a controller of a parameter to 'snapshot'. But I like the snapshots so much :) And: I know how easy it is to copy a preset in the editor, but I don't know how to easy copy a preset in the unit itself. I think I will stick with snapshots. Quote Link to comment Share on other sites More sharing options...
zooey Posted June 3, 2017 Share Posted June 3, 2017 Sorry I wasn't clearer. Pretty much all my real presets use snapshots, they're just awesome. I just meant that I'll often start a new preset by modifying an existing one, so a bunch of controller and switch assignments, as well as routing and processing choices, are already in place. Quote Link to comment Share on other sites More sharing options...
zooey Posted June 3, 2017 Share Posted June 3, 2017 To copy a preset on Helix itself, just click Save ONCE, then select a different destination patch. Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 3, 2017 Share Posted June 3, 2017 . And: I know how easy it is to copy a preset in the editor, but I don't know how to easy copy a preset in the unit itself. .... On the device itself saving a preset is a two-step process. After hitting the SAVE button once, you can select the destination location. Change the destination to a new location then hit the SAVE button the second time. That constitutes the COPY operation; there are now two identical versions of the preset and you can begin to edit either one. Quote Link to comment Share on other sites More sharing options...
LutherDeLorme Posted June 3, 2017 Author Share Posted June 3, 2017 Sorry I wasn't clearer. Pretty much all my real presets use snapshots, they're just awesome. I just meant that I'll often start a new preset by modifying an existing one, so a bunch of controller and switch assignments, as well as routing and processing choices, are already in place. Good idea!! Thanks man! :) And also thanks for your comment on how to copy a preset on the unit itself. Quote Link to comment Share on other sites More sharing options...
LutherDeLorme Posted June 3, 2017 Author Share Posted June 3, 2017 On the device itself saving a preset is a two-step process. After hitting the SAVE button once, you can select the destination location. Change the destination to a new location then hit the SAVE button the second time. That constitutes the COPY operation; there are now two identical versions of the preset and you can begin to edit either one. Thank you! :) Quote Link to comment Share on other sites More sharing options...
LutherDeLorme Posted June 3, 2017 Author Share Posted June 3, 2017 ......... In the editor, it's very fast as well. The shortcuts are: - Snapshot Assign Shortcut—OPTION-click (Mac) or ALT-click (PC) any Home screen parameter to quickly assign its value to the Snapshots controller....... I just checked it, and this is a great shortcut in the editor! Thanks a LOT for this very good trick!! :) This is really helpful. Now the controller is set to 'snapshot' ("bracket mode") extremely fast and easy. Thanks again. Quote Link to comment Share on other sites More sharing options...
