Use Your Illusion / Spaghetti Incident Impulse Response
FarleyUK
Hi guys,
I've been playing around with trying to create an IR based on the recorded guitar tone Slash has on the UYI and Spaghetti Incident albums. Brand new to this, but think I've got it fairly close...
I used Voxengo, Reaper and Ozone 7 to EQ match with the guitar track - feel free to give the IR a spin from here:
 https://dl.dropboxusercontent.com/u/46739309/UYI.wav
As I said, it's my first attempt, so please be gentle....!
Since ir's can be very customized, we need to know the other effects in the chain. Amp, overdrive, etc.
Does this replace the speaker cab or use along with a cab. Check out some of Glenn DeLaune's presets. He uses his own custom ir's along with cabs.
Cheers - yeah, I thought about Glenn's patches earlier, funnily enough.
When I've been trying this IR I captured, I use the 2204 amp with an OD pedal in front - normally a Minotaur - with the gain at 1, tone around 5.5 and Level around 6-7. The amp has gain at 6.5, Bass at between 5 and 7, Mids at around 6-7, Treble around 4.5, Presence at 7-8, Master at 6, Sag at 6.5, hum and ripple at 0, bias around 7.
I was just using it as an IR direct after the amp block.
Excellect reply! I'll have to check it out when I have time.
