guitarmech111 Posted September 22, 2013 Share Posted September 22, 2013 man, I am getting too tired of all the crud I have to go through to get this dream rig going after firmware updates. Took 4 times to get JTV59 updated with 2.0 after rolling it back as suggested - finally got that settled after 2.5 hours of no fun. Reset the HD500 back to get HD edit working with selecting the variax patches in the HD500 patches.again. I ended up flashing to latest firware again. This time the variax patches can be set in the HD Edit. Now it looks like after the flashing, the volume controller does not work. It did before all the flashing. This just makes me so irritated to almost no end! I don't really care to hear that someone's update went withotut a hitch. That won't help me. I am looking to see if someone has run into this or has a suggestion to get my volume pedal back on the HD500. TIA!. Quote Link to comment Share on other sites More sharing options...
guitarmech111 Posted September 22, 2013 Author Share Posted September 22, 2013 I neglected to add that I can set the volume pedal to the exp-1 in HD Edit and all the patches show the correct volumes for min and max. The pedal just doesn't work. Quote Link to comment Share on other sites More sharing options...
guitarmech111 Posted September 22, 2013 Author Share Posted September 22, 2013 Spoke too soon, the HD Edit is back to locking up when selecting the variax model... Quote Link to comment Share on other sites More sharing options...
guitarmech111 Posted September 22, 2013 Author Share Posted September 22, 2013 The volume works when I change it in HD Edit. This has to be bad optic sensors or a bad software update. The pedal worked before all this flashing... Quote Link to comment Share on other sites More sharing options...
guitarmech111 Posted September 22, 2013 Author Share Posted September 22, 2013 THX!! I got the volume pedal back. I can't believe I missed that. I feel like a fool. Now I need to get the latest HD Edit working with the latest Variax firmware. Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 22, 2013 Share Posted September 22, 2013 No - HD Edit works fine. It's Workbench HD that doesn't work right now using the HD500 VDI connection. 1 Quote Link to comment Share on other sites More sharing options...
guitarmech111 Posted September 22, 2013 Author Share Posted September 22, 2013 OK, if you have a dream rig, you are SOL if you can't find that little box... Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted September 23, 2013 Share Posted September 23, 2013 every time you flash the HD500 you must then do the pedal calibration follow the instructions here: http://line6.com/support/page/kb/_/effects/pod/pod-hd/pod-hd500xhd500-pedal-calibration-r161 This really should be part of the upgrade process and prompted for rather than relying on the user remembering 2 Quote Link to comment Share on other sites More sharing options...
euanhalket Posted September 30, 2013 Share Posted September 30, 2013 Hi I am using a james tyler variax with a pod hd500 and connecting with a varax cable.I am unable to hear the magnetic guitar pickups when I put the models off. I have hd500 input set to guit+aux+variax+ch1 and same for input 2 nothing seems to let me hear variax magnetic pickups unless I use normal guitar lead which works fine but I want to use variax lead at gigs so I don't have to worry about battery. Any help appreciated Quote Link to comment Share on other sites More sharing options...
GeiGit Posted October 1, 2013 Share Posted October 1, 2013 It can be the contact or a defect in your VDI-cable. Check it with a normal ethernet-cable (network-cable). It's not normal. I use also VDI."Variax" and "variax mags" working fine. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted October 1, 2013 Share Posted October 1, 2013 Hi I am using a james tyler variax with a pod hd500 and connecting with a varax cable.I am unable to hear the magnetic guitar pickups when I put the models off. I have hd500 input set to guit+aux+variax+ch1 and same for input 2 nothing seems to let me hear variax magnetic pickups unless I use normal guitar lead which works fine but I want to use variax lead at gigs so I don't have to worry about battery. Any help appreciated I'm pretty sure you have to have "Variax Mag" (or something like that, I'm not in front of my pod) selected. The cool thing about this is you can have the Variax model going into one input and the mags going into another. For example, for an electric, acoustic mix. Quote Link to comment Share on other sites More sharing options...
euanhalket Posted October 1, 2013 Share Posted October 1, 2013 hi thanks for replies yeah ive tried another cable and I also have tried all the input combinations but to no avail. It worked when I 1st got the guitar 3 weeks ago but stopped working at some point during last week. the normal guitar input works fine. Quote Link to comment Share on other sites More sharing options...
