Helix crashes in Cubase 9 Pro
atomicvai
Wondering if anyone else has had similar issues and found a solution.  I'm running on a fresh install of windows 10 Pro (1 week old) using Cubase 9 Pro 64 bit with latest updates.  Basic comp specs are 4930k, 32gb ram, SSD drives.  Using UAD Apollo quad interface.
When I try to insert Helix (VST3) on a channel it just gives me an error message and pops up a tiny plugin window that can't be resized or used at all (as in attached pics).  When I try the VST2 version I don't get the error, but I get the same tiny plugin window.
I've reached out to Line6, but their only response was to reinstall, which I've tried multiple times.
Any thoughts?
Wondering if anyone else has had similar issues and found a solution.  I'm running on a fresh install of windows 10 Pro (1 week old) using Cubase 9 Pro 64 bit with latest updates. ;Basic comp specs are 4930k, 32gb ram, SSD drives.  Using UAD Apollo quad interface.
Any thoughts?
I remember reading a similar problem concerning Ableton Live. The solution was apparently to uninstall either the VST2 or the VST3 version. As Cubase 9 of course is VST3 compliant, perhaps give uninstalling the VST2 version a go?
