zochar 0 Posted August 22, 2017 My Pod Farm doesn't show input and output in the mixer view. So i can 't select instrument in input. Can anyone help me with this problem? Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted August 22, 2017 Are you launching the plug-in or standalone? Quote Share this post Link to post Share on other sites
zochar 0 Posted August 23, 2017 Are you launching the plug-in or standalone? I'm using it in Cubase with the Studio GX. I can't hear the guitar when I play, but when i record and replay the track in Cubase, I can hear the guitar. Quote Share this post Link to post Share on other sites
fflbrgst 1,852 Posted August 23, 2017 As a plug-in, PodFarm would not show input and output, those are selected in your Cubase track options. Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted August 23, 2017 I'm using it in Cubase with the Studio GX. I can't hear the guitar when I play, but when i record and replay the track in Cubase, I can hear the guitar. A convenient work flow with the POD Studio is to monitor the wet with the standalone PF and capture the wet and dry simultaneously. The wet track you capture servers as a reference and the dry track you can apply the PF plug-in (and other plug-ins) post processing. Quote Share this post Link to post Share on other sites
zochar 0 Posted August 23, 2017 As a plug-in, PodFarm would not show input and output, those are selected in your Cubase track options. And where do i select them in Cubase? Quote Share this post Link to post Share on other sites
zochar 0 Posted August 23, 2017 A convenient work flow with the POD Studio is to monitor the wet with the standalone PF and capture the wet and dry simultaneously. The wet track you capture servers as a reference and the dry track you can apply the PF plug-in (and other plug-ins) post processing. Sorry Triryche, I'm a morron when it comes to technical things like this. This is the first time i use an interface with Cubase, so i'm on a limp here :-) Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted August 23, 2017 POD Farm 2 standalone, launched outside of Cubase in mixer view will have the dropdown selections for instrument/mic. Using this you can hear your tones in real time with or with out Cubase. POD Farm 2 plug-in is launched inside a host DAW, such as Cubase, and you cannot select instrument/mic because it is the track that is feeding it. In the standalone mixer view you can select what you send to your DAW. I typically arm 2 stereo tracks to record and send dry to one and wet to the other. Then after your take, insert an instance of the POD Farm plug-in on the dry track. I would suggest reading the manual and watching some youtube vids. Not being that great with the tech just means you have a bit of a learning curve, but it shouldn't take long to get over the hump. 1 Quote Share this post Link to post Share on other sites
Gaz_Ham 22 Posted August 29, 2017 I'm pretty new to podfarm( 2 days experience ) but I had trouble with inputs and cubase 5. I use standard alone at the moment, It let's you select the input there and the sound is still captured in cubase. I still haven't figured it out as a vst in cubase yet. Quote Share this post Link to post Share on other sites
RossEmbleton 0 Posted April 22, 2020 Hi all, I'm experiencing a similar problem. Any thoughts on why i'm not seeing the input options here? I used this UX1 for many years without this issue and now suddenly its gone. See image below: Thanks for your help in advance. Quote Share this post Link to post Share on other sites
