Dt25 Hd Direct Out To Audio Interface
Pwm5k
Hi, I'm just got my DT25 HD today. And I'm going to use the cabinet simulated direct out to my Focusrite Saffire Pro 24 audio interface, but I'm not sure which input to plug to, should I plug to line input or the preamp input of the audio interface? Thanks!
The Cabinet Simulated Direct Output on the rear of the DT-25 is a "microphone-level" sampling the output from the analogue circuitry just before it is fed to the speaker, to which a simulation of the speaker, cabinet and microphone defined in the POD HD preset have been applied.
You may need to use the Pre-Amp input on your Pro 24 to bring the level from the DT25 up to where you need it? As BigChase52 said ... try both to see which works best.
  • 1 year later...
did any of this work? I am trying to direct out to an audio interface (RME fireface UCX) and i just get no output at all - does anyone know what I might be doing wrong. I am directing the output into the microphone input on my interface with a microphone cable.
Do you have your DT in Standby ? Are you using LVM or not ? In normal mode the amp needs to be out of standby...
Sammy
Sammy
thanks for your response. I dont have my DT in standby and I am not using LVM. so yeh the amp doesnt work at all if its in standby does it?
In LVM it does, but in normal mode it does not, unfortunately... mmm, did you check the cable and mic input of the RME ?
