soundog Posted November 1, 2017 Share Posted November 1, 2017 Please vote for the ability to route the digital signal out, through other plug-ins, and back into Helix Native, to provide more flexibility and utility in processing. Here's the link https://line6.ideascale.com/a/idea-v2/915257 and here's the Idea Scale submission: It would be useful to have a "send" block to route the digital signal out of Helix, where the user could then route through external DAW plugins, and then back into a Helix "return" block. This would be similar to using Sends and Returns in the hardware unit to use external pedals. Example: Track 1 Helix Native (amp + cabinet) ---> virtual Out Port 1 ---> Track 2 other plug-ins ---> virtual Out Port 2 ---> back into Track 1 Helix Native (after the amp + cabinet blocks) --> final Out User could, for example, use a third-party IR loader that access a larger library of IR files, without having to load them into Helix Native. Or, user could use favorite high end compressor EQ, or effects plug-ins within the Native Helix chain (rather than being restricted to before or after Helix Native). 1 Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted November 2, 2017 Share Posted November 2, 2017 Voted.I have no idea how easy this would be to implement though - it would seem that adding the ability to load external VST within Native (new extension to the UI required here) might be easier than to interact with the multitude of DAW choices. Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 2, 2017 Share Posted November 2, 2017 It really wouldn't be loading another plug-in within Helix Native, it would route I/O to an FX bus or other track in your DAW. I could see this also being able to add external pedals if your interface has the appropriate I/O. Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 2, 2017 Share Posted November 2, 2017 Ha! Rewolf, I misread your post!! Quote Link to comment Share on other sites More sharing options...
soundog Posted November 2, 2017 Author Share Posted November 2, 2017 In Logic Pro, we use AU plug-ins, not VSTs. Regardless, hosting plug-ins within Helix Native would serve the same function as I am suggesting. Also, I realize that multiple DAWs might implement virtual I/O routing differently, and that could be a challenge. Or not? I'm not sure which method would be easiest (or possible) to implement (hosting plug-ins within Native, or routing in/out of Native), but it sure would be a handy dandy feature. Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted November 2, 2017 Share Posted November 2, 2017 It is the only way to have a Helix patch using FX Loops compatible with a Native patch... assuming that can find plugins that match what you want in the FX loop (or route physically). Personally I don't use external pedals, but inserting synths I sometimes do and I am toying with MIDI Guitar (Jam Origin) Quote Link to comment Share on other sites More sharing options...
soundog Posted November 3, 2017 Author Share Posted November 3, 2017 ...seems like the best way to duplicate or mimic the Helix Send/Return blocks (i.e. FX loops) in Helix Native would be to use Send/Return virtual routing blocks. Then, its up to the user what external pedal they want (for the hardware Helix); or whatever external plug-ins they want (for Helix Native). I've got some pretty amazing effects plug-ins, as well as IR loaders, compressors, and EQs that I'd love to be able to patch in to a Helix Native chain, rather than be limited to sticking them before or after Helix Native. Enabling Send and Return blocks in Native would make the software more consistent with — and similar to — the hardware units. 1 Quote Link to comment Share on other sites More sharing options...
kevinwal Posted February 9, 2018 Share Posted February 9, 2018 You can achieve the same effect by using multiple instances of Helix Native. In->1st HN -> aux track w plugins -> 2nd instance of HN Quote Link to comment Share on other sites More sharing options...
tommasoferrarese Posted February 9, 2018 Share Posted February 9, 2018 I think they should simply introduce a convenient way of merging multiple patches from native into a single HW Helix patch, to grant continuity between the plugin in the studio and the touring hardware. Quote Link to comment Share on other sites More sharing options...
multisusc Posted April 22, 2021 Share Posted April 22, 2021 I totally agree with Tommas and Sounddog . I have an 8 in/8 out sound interface and if they implemented the send/return solution I could use them to go to my VOX AC30 head and back to the helix the same way my Helix floor (beautifully) does. The valve AC30 is my core sound but I only go to the AC30 pre amp after I apply some EQ and Compression in the helix path. It woudl be great if they could implement this in the Helix Native as it would then turn into a true solution to emulate my live gear. Quote Link to comment Share on other sites More sharing options...
markwesse Posted September 8, 2023 Share Posted September 8, 2023 On 11/2/2017 at 10:23 AM, soundog said: Please vote for the ability to route the digital signal out, through other plug-ins, and back into Helix Native, to provide more flexibility and utility in processing. Here's the link https://line6.ideascale.com/a/idea-v2/915257 and here's the Idea Scale submission: It would be useful to have a "send" block to route the digital signal out of Helix, where the user could then route through external DAW plugins, and then back into a Helix "return" block. This would be similar to using Sends and Returns in the hardware unit to use external pedals. Example: Track 1 Helix Native (amp + cabinet) ---> virtual Out Port 1 ---> Track 2 other plug-ins ---> virtual Out Port 2 ---> back into Track 1 Helix Native (after the amp + cabinet blocks) --> final Out User could, for example, use a third-party IR loader that access a larger library of IR files, without having to load them into Helix Native. Or, user could use favorite high end compressor EQ, or effects plug-ins within the Native Helix chain (rather than being restricted to before or after Helix Native). Yes Yes and Yes And while at it...allow Helix hardware fx sends to use USB as destinations...otherwise its clunkville Quote Link to comment Share on other sites More sharing options...
datacommando Posted September 8, 2023 Share Posted September 8, 2023 On 9/8/2023 at 9:58 AM, markwesse said: Yes Yes and Yes And while at it...allow Helix hardware fx sends to use USB as destinations...otherwise its clunkville Hi, You may have to wait quite some time. It seems the original link provided by @soundog is broken, but there is this one, that both he and I upvoted. Sadly, only 33 votes in total since 2017. Ho, hum! link: https://line6.ideascale.com/c/idea/40496 Quote Link to comment Share on other sites More sharing options...
markwesse Posted September 8, 2023 Share Posted September 8, 2023 On 9/8/2023 at 8:35 PM, datacommando said: Hi, You may have to wait quite some time. It seems the original link provided by @soundog is broken, but there is this one, that both he and I upvoted. Sadly, only 33 votes in total since 2017. Ho, hum! link: https://line6.ideascale.com/c/idea/40496 Wow...it musnt be very visible...absolutely essential Quote Link to comment Share on other sites More sharing options...
soundog Posted September 17, 2023 Author Share Posted September 17, 2023 Ho hummmmm indeed. Native gets little love, just leveraged code from the hardware. The only pinned note on this forum is still for Version 1.5! And there is STILL no standalone version for Native. Ho ho ho! 1 Quote Link to comment Share on other sites More sharing options...
