MolchMon Posted November 17, 2017 Share Posted November 17, 2017 Howdy, New to Variax/Shiruken. When playing a plucked harmonics on the 12th, 9th, 7th, and 5th frets, an odd and unattractive warbling occurs when using the 1970 Martin model. For example, imagine playing the into to Yes' 'And You And I'. Every time you pluck a harmonic, the note you are intending to gets scooped into from the note below kind of like the way a singer scoops into ascending notes while searching for the right note to sing. That's what the 1970 Martin 12 string does when harmonics are plucked on it. Any remedies for that? Thanks for your wisdom and knowledge, MM Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted November 17, 2017 Share Posted November 17, 2017 Howdy, New to Variax/Shiruken. When playing a plucked harmonics on the 12th, 9th, 7th, and 5th frets, an odd and unattractive warbling occurs when using the 1970 Martin model. For example, imagine playing the into to Yes' 'And You And I'. Every time you pluck a harmonic, the note you are intending to gets scooped into from the note below kind of like the way a singer scoops into ascending notes while searching for the right note to sing. That's what the 1970 Martin 12 string does when harmonics are plucked on it. Any remedies for that? Thanks for your wisdom and knowledge, MM You're not gonna get rid of that. The tuning algorithms which create the 12 string effect are not perfect, and some weird tracking issues happen with harmonics, particularly if you strike more than one and allow them to ring together. It's not peculiar to the Shuriken... the JTV's all exhibit this too. There are YouTube videos demonstrating exactly what you're talking about. The technology has it's limits. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 20, 2017 Share Posted November 20, 2017 Warbling is usually a result of the pick-up to string distance adjustment. If it's more of a whistling howling, the intonation needs to be dialed in tighter. Have the set-up checked by a Line 6 authorized service center. Make certain your guitar is registered in your account. Quote Link to comment Share on other sites More sharing options...
