Bovine Posted February 24, 2018 Share Posted February 24, 2018 Hi all, I have discovered that after updating my Helix to 2.50, when I change snapshots my external amp channel is no longer changing. I have two different external amps I use depending on what is required with a separate setlist set up for which amp I am using and the fault is common on both setups. The light ring around the appropriate footswitch lights up, but the relay doesn't appear to trigger. It works if I turn the assigned footswitch off and back on again and have tried reconfiguring the snapshot with no luck. I have reset the unit and reinstalled my back up with the same result. So far the only fix I have found was to reinstall V2.30 firmware so the problem seems to be in the latest update. Anyone else experiencing this issue? I would love to get this working as I have a song that requires the Seeker and voice box effects which are only available in the latest update. Thanks Steve Quote Link to comment Share on other sites More sharing options...
phil_m Posted February 24, 2018 Share Posted February 24, 2018 This is known bug and will be fixed shortly. 1 Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted February 24, 2018 Share Posted February 24, 2018 V2.52 is supposed to have fixed this. It came out yesterday, but has been pulled temporarily. 1 Quote Link to comment Share on other sites More sharing options...
Bovine Posted February 24, 2018 Author Share Posted February 24, 2018 Thanks, I look forward to the upcoming update. Quote Link to comment Share on other sites More sharing options...
cms1620 Posted February 25, 2018 Share Posted February 25, 2018 Its completely jacked mine up even when i go back to previous up date my snapshots only blink. When you select them the small screens go blank. Quote Link to comment Share on other sites More sharing options...
phil_m Posted February 25, 2018 Share Posted February 25, 2018 Its completely jacked mine up even when i go back to previous up date my snapshots only blink. When you select them the small screens go blank. This sounds like there's simply a Global Setting that changed. If you go to Global Settings>Footswitches, under Knob 4, you'll see Snapshot Mode Switches". If that's set to "Auto Return" it will do what you're describing. It goes back to Stomp Mode automatically after you select a snapshot. Set it to "Manual Return" if you want to remain in Snapshot Mode after selecting a snapshot. If your scribble strips are blank in Stomp Mode, it simply means you haven't assigned anything to them. Quote Link to comment Share on other sites More sharing options...
