Lachdanan0121 Posted February 26, 2018 Share Posted February 26, 2018 Or are these bugs (such as the delay pitching issue) only present in the hardware? Quote Link to comment Share on other sites More sharing options...
zolko60 Posted February 26, 2018 Share Posted February 26, 2018 Can you adress any topics about "delay pitching issue"? You mean "glitching"? http://line6.com/support/topic/29514-delay-glitch-when-choosing-another-snapshot-with-different-delay-time/I actually love that glitch when changing snaphots :D Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 26, 2018 Share Posted February 26, 2018 I expect there will be no associated update for Helix Native. My reasoning is that v2.52 firmware was released, then pulled temporarily due to unexpected (and serious) issues for a few users. These issues were reported by Line 6 as being confined to the Line 6 Updater program so will not affect Helix Native. Since there was no Helix Native release when v2.52 was released I don't anticipate one now. Quote Link to comment Share on other sites More sharing options...
Lachdanan0121 Posted February 26, 2018 Author Share Posted February 26, 2018 "In rare cases, pitch artifacts may be heard on selected delay blocks when the Time parameter is set to Note Sync values higher than 1/2 Triplet." That is listed under "known issues" in the newest update that was pulled. I understand if the update won't come to Native since it was pulled. I guess I was mainly asking if the above "delay pitching issue" is only an issue in the hardware, or also present on Native? If it is also present in Native, will the next update address it? Quote Link to comment Share on other sites More sharing options...
zolko60 Posted February 26, 2018 Share Posted February 26, 2018 How rare is that issue? Do you experience such cases? In what circumstances? 1/2 note is higher value than 1/2 triplet or lower? Quote Link to comment Share on other sites More sharing options...
Lachdanan0121 Posted February 26, 2018 Author Share Posted February 26, 2018 I am not sure that I have, I was largely just curious. Not sure on the answer to your second question. Quote Link to comment Share on other sites More sharing options...
zolko60 Posted February 27, 2018 Share Posted February 27, 2018 So if anybody prooves such a phenomenon exists, somebody will have chance to spot it.Let's treat it as non-existent until then;) Quote Link to comment Share on other sites More sharing options...
soundog Posted February 28, 2018 Share Posted February 28, 2018 Should be easy enough to test on your own. If you aren't itching, you don't have bugs. Quote Link to comment Share on other sites More sharing options...
zolko60 Posted February 28, 2018 Share Posted February 28, 2018 There is always some workaround. You can build 1/2 note delay from three 1/2 triplets. :D(joke) Quote Link to comment Share on other sites More sharing options...
cruzfolmli Posted March 30, 2018 Share Posted March 30, 2018 Is there going to be the fix for the new reverbs when on mono? This was fixed on one of the newer releases for helix. What happens is the volume of the reverb when it is set to mono is so small. When you set the block to stereo (still outputting as mono) the reverb is much bigger. Quote Link to comment Share on other sites More sharing options...
soundog Posted March 30, 2018 Share Posted March 30, 2018 Interesting. I would guess Line 6 would save up the hardware code fixes and fold them into the next Helix Native update, whenever that is. Quote Link to comment Share on other sites More sharing options...
cruzfolmli Posted April 2, 2018 Share Posted April 2, 2018 Yep sure would hope so - I've emailed support with the bug also. What set up do you use? Quote Link to comment Share on other sites More sharing options...
soundog Posted April 2, 2018 Share Posted April 2, 2018 Mexican strat, Variax standard, Music Man bass ---> Apollo Twin audio interface ---> Logic Pro X + Helix Native. Quote Link to comment Share on other sites More sharing options...
