rudomat Posted May 29, 2018 Share Posted May 29, 2018 hi, i´m running my hx fx in 4CM, using my expression pedal to toggle between a rhythm sound in heel down position (less gain, very little delay, etc...) and a lead sound in toe down position (level boost, much delay, etc...) now for my higher gain sounds i´m searching for a solution to be able to add a gain boost as well for the toe down position...but i guess there´s no boost or distortion pedal that offers a mix parameter, so i could set it to 0% in heel down position, is there...? is there a way to bypass a block with an expression pedal in one position...? thanks for ideas!! ;-) Quote Link to comment Share on other sites More sharing options...
themetallikid Posted May 29, 2018 Share Posted May 29, 2018 why not just use a gain block, and have it go from Heel 0% (0db) to Toe 100% (Xdb, as much db boost as you need) that you want it to add for gain Quote Link to comment Share on other sites More sharing options...
rudomat Posted May 30, 2018 Author Share Posted May 30, 2018 12 hours ago, themetallikid said: why not just use a gain block, and have it go from Heel 0% (0db) to Toe 100% (Xdb, as much db boost as you need) that you want it to add for gain sorry my stupid question...but what do you mean by "gain block"...? thanks Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 30, 2018 Share Posted May 30, 2018 6 hours ago, rudomat said: sorry my stupid question...but what do you mean by "gain block"...? thanks There's a Gain block in the same menu as the Volume block. Unlike the Volume block, it allows you to boost as well as cut. Quote Link to comment Share on other sites More sharing options...
themetallikid Posted May 30, 2018 Share Posted May 30, 2018 Right so you could run from -3db to +3db from heel to toe. or whatever range you wanna create. Quote Link to comment Share on other sites More sharing options...
