pjay24 Posted October 23, 2013 Share Posted October 23, 2013 Hello, Yesterday my new Variax JTV-89 came, unfortunately pushing Guitar Model Selector doesn't start variax, LED won't lit :/ Battery is fully charged. Does anyone know what is the problem? I thought that changing firmware to 2.0 will help, unfortunately, after installing version 2.0 problem is the same. Sorry form my English ;) Best regards Pawel Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted October 23, 2013 Share Posted October 23, 2013 Well if 2.0 installed the processor electronics is running. It is probably a problem with the switch itself. Try removing the knob and pushing on the shaft. Many here have experienced this problem with that switch not activating. If that doesn't work send it back. Quote Link to comment Share on other sites More sharing options...
ricuff Posted January 30, 2014 Share Posted January 30, 2014 I have same problem variax mode not activating, I tried reinstall firmware but no help, If i connect the variax to usb the red led in the side of the variax blinks, th other led is green. What could I do? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted January 30, 2014 Share Posted January 30, 2014 I have same problem variax mode not activating, I tried reinstall firmware but no help, If i connect the variax to usb the red led in the side of the variax blinks, th other led is green. What could I do? You need a fully charged battery AND plug a 1/4" cable into the jack to turn the Variax on, otherwise the USB dongle will think that nothing is connected. Quote Link to comment Share on other sites More sharing options...
ricuff Posted January 30, 2014 Share Posted January 30, 2014 thanks, I plugged the 1/4" cable and now both led are green but workbench hd still show no device connected, and variax button does not lid thanks Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted January 30, 2014 Share Posted January 30, 2014 thanks, I plugged the 1/4" cable and now both led are green but workbench hd still show no device connected, and variax button does not lid thanks Close Workbench, then try connecting to Line6 Monkey first. If that recognizes the guitar, then reopen Workbench. Failing that, reboot the whole computer and try again. The whole setup gets cranky sometimes and doesn't want to cooperate...I've had to fiddle with it to get it to see the guitar as well. Don't know why it works one day and not others...but most likely it will work eventually if you poke at it long enough. Quote Link to comment Share on other sites More sharing options...
ricuff Posted January 30, 2014 Share Posted January 30, 2014 thanks now workbench recognize the guitar and led are both green, but still the variax button does not work and does not lid when pressed thanks Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted January 30, 2014 Share Posted January 30, 2014 thanks now workbench recognize the guitar and led are both green, but still the variax button does not work and does not lid when pressed thanks You may have a dead switch then...open up a support ticket with Line 6 and see what they tell you. Good luck... Quote Link to comment Share on other sites More sharing options...
simcogw Posted May 1, 2014 Share Posted May 1, 2014 pulling the knob did the trick for me ("uh huh huh he said knob" in his best butt head voice) turns out it had been smashed down a bit not leaving enough clearance to engage the switch i love mechanical issues :) hope this helps someone Quote Link to comment Share on other sites More sharing options...
Extremegain Posted July 12, 2014 Share Posted July 12, 2014 "pulling the knob" was a solution :) I had the same problem with Variax JTV-89. I started to think that sth is really messed up. When you pull knob just a little bit (you can totally pull it out if you want to look inside), it starts to work. Indeed smal mechanical issue, but really hard to find. Thnx much for help :D Quote Link to comment Share on other sites More sharing options...
clay-man Posted July 13, 2014 Share Posted July 13, 2014 If it ever keeps happening again, take off the knob and put something in the hole to make a shim so it doesn't fall back down to the point where it does that again. Quote Link to comment Share on other sites More sharing options...
snhirsch Posted July 13, 2014 Share Posted July 13, 2014 pulling the knob did the trick for me ("uh huh huh he said knob" in his best butt head voice) turns out it had been smashed down a bit not leaving enough clearance to engage the switch i love mechanical issues :) hope this helps someone Just incredible to see that this problem is still chronic. Even if Line6 is not in a financial position to retool the plastic molding, one would think they could start installing a shim on all production units... 1 Quote Link to comment Share on other sites More sharing options...
orbitus Posted April 20, 2021 Share Posted April 20, 2021 Used I took the JTV69 and I have a similar problem. Epoxy I pressed the button, it works, but it must be very strong. Button change?! Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 20, 2021 Share Posted April 20, 2021 orbitus,... I don't see a service history and it's and early serial number. It's probably time to have a Line 6 authorized service center to check it out and give it a good looking over. https://line6.com/find/service_center/ Quote Link to comment Share on other sites More sharing options...
