tallikaz Posted June 27, 2018 Share Posted June 27, 2018 Is there any way to move between snapshots? I mean directly through them. For example, in the snapshot mode I have 4 different ones (5A, 5B, 5C and 5D). Can I go up and down via stomps? I know I can get it using the big knob, what would be cool if there's a way to do it with my feet. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 27, 2018 Share Posted June 27, 2018 Yes. You can assign the Up/Down switches to move you sequentially through Banks, Presets, or Snapshots. From the manual: SHORTCUT: At any time, press and hold both FS1 and FS7 to cycle through BANK /, PRESET /, and SNAPSHOT /. Quote Link to comment Share on other sites More sharing options...
tk78 Posted June 27, 2018 Share Posted June 27, 2018 When you tap on Mode (most right, upper foot switch), you should get into the Snapshot Mode. Then can just tap on which Snap Shot directly. In Global Settings -> Footswitches, 2nd menu from left you can set up the default mode. Usually I got it on 8 Snapshots, you can also set a mix of stomp and snap shots assignments there. Hope that helps. Cheers, Thomas Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 27, 2018 Share Posted June 27, 2018 1 minute ago, tk78 said: When you tap on Mode (most right, upper foot switch), you should get into the Snapshot Mode. Then can just tap on which Snap Shot directly. In Global Settings -> Footswitches, 2nd menu from left you can set up the default mode. Usually I got it on 8 Snapshots, you can also set a mix of stomp and snap shots assignments there. Hope that helps. Cheers, Thomas You actually don't get into Snapshot Mode by hitting the Mode footswitch. Hitting the Mode switch toggles between Stomp and Preset Mode. It's just in your case, you have Preset Mode set 8 Snapshots in the Global Settings menu (which is what I do to). To get into Snapshot Mode from Stomp or Preset Mode, you hit the Bank Up and Bank Down buttons together. Not trying to be pedantic about it. Just trying to avoid confusion as how you access the different modes seems to be a source of confusion for quite a few people. Quote Link to comment Share on other sites More sharing options...
tallikaz Posted June 27, 2018 Author Share Posted June 27, 2018 Thanks, but I'm afraid that's the way in the Helix model. Mine is the HX Effects :) Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 28, 2018 Share Posted June 28, 2018 (edited) On 6/27/2018 at 8:18 AM, phil_m said: You actually don't get into Snapshot Mode by hitting the Mode footswitch. Hitting the Mode switch toggles between Stomp and Preset Mode. It's just in your case, you have Preset Mode set 8 Snapshots in the Global Settings menu (which is what I do to). To get into Snapshot Mode from Stomp or Preset Mode, you hit the Bank Up and Bank Down buttons together. Not trying to be pedantic about it. Just trying to avoid confusion as how you access the different modes seems to be a source of confusion for quite a few people. On 6/27/2018 at 9:40 AM, tallikaz said: Thanks, but I'm afraid that's the way in the Helix model. Mine is the HX Effects :) Page 25 of the HX Effects v2.50 Owner's manual.... Edited April 9, 2019 by rd2rk Image removed to recover attachment allotment Quote Link to comment Share on other sites More sharing options...
MarkSalore Posted June 28, 2018 Share Posted June 28, 2018 Does this also pertain the the regular Helix floorboard unit or just the FX? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 28, 2018 Share Posted June 28, 2018 Both. Page 36 Helix 2.0 Owners Manual - Rev D. Quote Link to comment Share on other sites More sharing options...
