DanielVH Posted July 31, 2018 Share Posted July 31, 2018 Does anyone have any experience running the pod HD500x in front of an amp, I understand that the 4 cable method is preferred (or an FRFR) but my current amp does not have an effects loop. I'm interested in the pod HD500x for direct recording and silent practice (headphones), but I was wondering if the pod HD500x would also be good in front of an amp (as a multiFX unit). Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted August 1, 2018 Share Posted August 1, 2018 The main issue with changing any sound source is going to be tone. There is no problem using it this way or that way or the other way. You simply will sound different each way. This can be a problem when designing tones because what sounds good here doesn't sound good there. Quote Link to comment Share on other sites More sharing options...
ts020572 Posted August 1, 2018 Share Posted August 1, 2018 I used the POD HD500 in front of my amp, for wahwah, compression, chorus, boost.... It is possible, but you have to get the levels right. I used it with these settings: studio direct, all FX in path A, mixer at 0 db, pan in the middle, path B muted, master volume at 100%. It also is a very flexible midi-controller, if your amp can handle midi. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted August 1, 2018 Share Posted August 1, 2018 Sure you could use it for FX such as Distortion, Compression, Noise Gate, etc in front of the amp. Set it to Studio Direct out and pay attention to levels. You may even get some of the Pre Amp Models to work fairly good too. But that will take some tweaking. Quote Link to comment Share on other sites More sharing options...
codamedia Posted August 1, 2018 Share Posted August 1, 2018 I've done this several times. It works great as a pedal board in front of an amp, just don't turn on any amp modeling. Use it strictly as a pedal board. Quote Link to comment Share on other sites More sharing options...
