Thenizze
pitch whammy octave clear? 100%?
Hello, I know this issue have been mentioned before, but I don't find the right answer.
I've got Pitch whammy set to heel pos.0 toe pos. -24. with Expression pedal 1.
Only when I activate the snapshot with this pitch whammy it points -24. When I use the expression pedal up and down it only goes to -23.
Off octave. I read about the automatic calibration and it sometimes does occur, sometimes it works fine.
Any ideas?
The snapshot will store the position of the pedal when it's saved, so if you want it to be at 0 when activated, make sure to have it at 0 when you save the snapshot. As for not reaching to full travel, you may have to tweak the pedal itself and make sure the pot is turning as far as it should, etc.
Good luck!
15 hours ago, brue58ski said:
Do you have the LT? If you do, it's being discussed here.
Hi Brue,  yes I do have the LT and read this discussion, but as said, there is no solution. I have to use my external Digitech Whammy.
