GuyDubus 0 Posted September 18, 2018 What setting do I use to get the best sounds ? Helix through Line 6 digital L3M. Do I use setting PA or Electric Guitar ? Quote Share this post Link to post Share on other sites
Fuaimador 1 Posted September 18, 2018 The silly answer is try both & you choose, but if there is more than the Helix going through the speaker I would use the PA setting. 1 Quote Share this post Link to post Share on other sites
Urmph 0 Posted October 4, 2018 Very timely. I just bought a second hand L3M and I’m having some trouble with it. In electric guitar mode it sounds excellent with the Helix plugged straight into the L3M. If I plug a music source into it, such as my phone, it sounds great in PA/Reference mode. Also, if I plug my electronic drum kit into it on PA mode it also sounds excellent. However, if I switch it to monitor or PA mode and plug the guitar into it any distorted guitar settings sounds dreadful. It sounds raspy and tinny and is unusable. Clean sounds are mostly fine. I bought the speaker to jam with some friends and have a Yamaha analogue mixer so figured I could set it to PA/Reference mode and connect us all to it via the mixer. I’ve compromised a bit by leaving it in electric guitar mode and tinkering with the mixer and the drum module to get a good sound out of the drums. However, I figure I must be doing something wrong. Any suggestions? Quote Share this post Link to post Share on other sites
slydawg65 0 Posted October 5, 2018 just use the L6 link. Quote Share this post Link to post Share on other sites
silverhead 8,822 Posted October 5, 2018 16 hours ago, Urmph said: Very timely. I just bought a second hand L3M and I’m having some trouble with it. In electric guitar mode it sounds excellent with the Helix plugged straight into the L3M. If I plug a music source into it, such as my phone, it sounds great in PA/Reference mode. Also, if I plug my electronic drum kit into it on PA mode it also sounds excellent. However, if I switch it to monitor or PA mode and plug the guitar into it any distorted guitar settings sounds dreadful. It sounds raspy and tinny and is unusable. Clean sounds are mostly fine. I bought the speaker to jam with some friends and have a Yamaha analogue mixer so figured I could set it to PA/Reference mode and connect us all to it via the mixer. I’ve compromised a bit by leaving it in electric guitar mode and tinkering with the mixer and the drum module to get a good sound out of the drums. However, I figure I must be doing something wrong. Any suggestions? Try experimenting with Helix presets that do/don't use a mic/cab/IR block. Theoretically when you set the L3 speaker to Elictric Guitar mode you can do without a Helix mic/cab/IR block since the speaker setting simulates that. When the speaker is set to PA or Monitor mode you should use the Mic/cab/IR block in the Helix preset. But there are no rules...... experiment with the Helix preset (EQ, amp bias, cab Lo/Hi cut, mic selection, ...) until you get a good sound with the speaker in PA mode. That's the mode I would use if you're using a mixer and other sound sources are in play. Quote Share this post Link to post Share on other sites
Urmph 0 Posted October 6, 2018 On 10/5/2018 at 1:25 PM, silverhead said: Try experimenting with Helix presets that do/don't use a mic/cab/IR block. Theoretically when you set the L3 speaker to Elictric Guitar mode you can do without a Helix mic/cab/IR block since the speaker setting simulates that. When the speaker is set to PA or Monitor mode you should use the Mic/cab/IR block in the Helix preset. But there are no rules...... experiment with the Helix preset (EQ, amp bias, cab Lo/Hi cut, mic selection, ...) until you get a good sound with the speaker in PA mode. That's the mode I would use if you're using a mixer and other sound sources are in play. Thanks. I’ve cured it. Would you believe it was a duff cable. In fact, two duff cables both brand new. It seems in my various attempts at plugging it all together I only ever used the working cables when it was in guitar mode. A process of elimination found the issue. Weird. Everything sounds brilliant now. What a speaker the L3M is. Quote Share this post Link to post Share on other sites
