Hx Effects and EVH5150III
ivanmongiardo
You have to press the button with those three parallel lines to open the menu first. Then it's:
Global Settings >>>> Turn BIG knob to select Ins/Outs >>>> Use knobs 1 - 3 to select line or instrument level depending on what you're trying to do.
That's it.
https://line6.com/data/6/0a020a3d3f4a5a6a1897ecdf6/application/pdf/HX Effects 2.50 Owners Manual - English .pdf
That's it.
Thanks, but I know how to set line level or instrument level. This is not the point. The point is that the amp has line level loop and you can choose or instrument level or line level for both send and return jack on the Hx, not separately. So I'm asking how other users are setting this and how it sounds.
From other research these are the options I found:
a. Set the output and the fx loop to line level. Then tweak the send parameter to -12dB into the fx loop block
b. Set the output to line level, and the loop to instrument level. Then twek the return parameter to -12dB into the fx loop block.
  • 1 month later...
