kerryhall1 Posted December 14, 2018 Share Posted December 14, 2018 Let's say I'm using the 7 cable method, and in my stereo FX loop path I have a parametric EQ. Is it possible to have different settings for L and R for this EQ? Quote Link to comment Share on other sites More sharing options...
jws1982 Posted December 14, 2018 Share Posted December 14, 2018 Nope, not unless: 1. Line 6 makes a stereo EQ effect that has separate controls for left and right 2. You split your signal into two chains after the FX return, pan hard L and R, and put an EQ block on both signal chains. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted December 14, 2018 Share Posted December 14, 2018 #2) EQ block on both paths. 1 Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 14, 2018 Share Posted December 14, 2018 Which device are you talking about with this setup? If you're talking about the Helix, LT or Rack, it would be pretty simple, as you have a lot of blocks to work with, and the easiest way to set up the 7CM would be to use separate paths for both amps. Quote Link to comment Share on other sites More sharing options...
kerryhall1 Posted December 14, 2018 Author Share Posted December 14, 2018 This is for the helix rack unit. So basically I can have two stereo signal paths, one before the preamp, and one in the fx loop, both paths running stereo fx (para eq in this case) with different settings for left and right? Thanks! Quote Link to comment Share on other sites More sharing options...
feffa86 Posted December 14, 2018 Share Posted December 14, 2018 Yes, there are many ways you can route this to achieve your goal. I would use path 1a as a stereo path and split it to two outputs at the very end, to go to each amp's input. Then from fx send of each amp into paths 2a and 2b, treat those as mono paths, but join them into one path at the end, with a single stereo output. If you place stereo effects before the split on path 1, or after the merge on path 2, you will retain the true stereo effect. If you want the same effect in both amps, place it on path 1 before the split,or on path 2 after the merge. If you want separate effects to each amp, place them on path 2a or 2b before the merge. Pie. Quote Link to comment Share on other sites More sharing options...
kerryhall1 Posted December 14, 2018 Author Share Posted December 14, 2018 Awesome! Thank you so much :) Quote Link to comment Share on other sites More sharing options...
kerryhall1 Posted December 17, 2018 Author Share Posted December 17, 2018 I tried out a Helix today, how do you select two different mono input paths for path 2? On the unit I was trying it only had a place to select inputs for 1 and 2, not 1a, 1b, 2a, 2b. Thanks! Quote Link to comment Share on other sites More sharing options...
kerryhall1 Posted March 28, 2024 Author Share Posted March 28, 2024 Coming back to this...I would still like the ability to set different settings for left and right when running stereo effects, not just eq, but any effect. I'm running stereo signals both before the preamps of my two amps, and in the fx loops of both amps. Is this doable now? (maybe it's been implemented?) Quote Link to comment Share on other sites More sharing options...
