ernsttore Posted December 15, 2018 Share Posted December 15, 2018 Maybe not the right forum for discussing this but hope someone can help. My Hughes&Kettner TubeMeister 40 deluxe have some soundbleed when the effectloop is activated, nothing on my clean channel but both crunch and lead channels. Thing is that when connecting my Helix in 4cm mode with this amp some of the sound is going directly to the speakers when the loop is activated, and since digital gear have some latency there will be this unpleasant phasing effect.... isn’t the effectloop 100% serial on these amps? Just curious if there’s anyone that have experienced this with these amps? Quote Link to comment Share on other sites More sharing options...
CraigGT Posted December 15, 2018 Share Posted December 15, 2018 I've got a Tubemeister 36 and never come across this problem, try unplugging the loop cables at the Helix end, if you still get sound it's your amp and if you don't it's something on the Helix. Craig Quote Link to comment Share on other sites More sharing options...
CraigGT Posted December 15, 2018 Share Posted December 15, 2018 The mix parameter on your Helix fx loop is a likely candidate, it should be on 100% Craig Quote Link to comment Share on other sites More sharing options...
ernsttore Posted December 15, 2018 Author Share Posted December 15, 2018 42 minutes ago, CraigGT said: I've got a Tubemeister 36 and never come across this problem, try unplugging the loop cables at the Helix end, if you still get sound it's your amp and if you don't it's something on the Helix. Craig Thanks for the reply, it’s definitely something wrong with the amp because with nothing plugged in the effectloop of the amp it still have this issue, have contacted Thomann were I bought it and they have contacted Hughes&Kettner directly ,and this was the answer they got from them: "It can reproduce this behavior but it is not considered as a fault – because you normally switch the fx-loop off when it is not used" Of coarse it’s not a problem when nothing plugged in and loop off, but the problem starts when i connect my Helix to the loop of the amp as i have told them from the very beginning, the soundbleed is still present. Thomann can not help me with this since H&K tells them that this is not a fault, so i’m thankful to hear other users experience about this amps effectloop before i contact H&K myself.... Thanks... Quote Link to comment Share on other sites More sharing options...
CraigGT Posted December 15, 2018 Share Posted December 15, 2018 if you plug jacks that are not connected to anything into the FX send and return, if you can get a sound with the loop turned on then I'd say it was definitely faulty. Craig Quote Link to comment Share on other sites More sharing options...
ernsttore Posted December 15, 2018 Author Share Posted December 15, 2018 1 hour ago, CraigGT said: if you plug jacks that are not connected to anything into the FX send and return, if you can get a sound with the loop turned on then I'd say it was definitely faulty. Craig Yep, i agree... I get this soundbleed even when nothing is plugged in the loop with the loop on, it is dead quiet on the clean channel when loop on, even volume on full, but not on the crunch and lead channels with the loop on,and the sound gets louder as I turn up the volume, does not help to turn the volume all the way down, i can still hear some sound coming from the cabinet.... (Helix is totally disconnected, just my gitar plugged in the amp) If this is not the case with your amp, it’s working as it should, and mine does certainly have a faulty FX loop... Thanks Quote Link to comment Share on other sites More sharing options...
CraigGT Posted December 16, 2018 Share Posted December 16, 2018 I just checked mine with a guitar plugged in the front and nothing in the back, With the loop switch off it works as expected, With the loop switched on I get nothing Patch the send and return with a cable and it comes back on. All exactly as you would expect, if yours is behaving differently then I'd suggest that it's faulty. The manual describes it as a serial fx loop and that's how I'd expect it to work. Craig Quote Link to comment Share on other sites More sharing options...
CraigGT Posted December 16, 2018 Share Posted December 16, 2018 Actually I just tried switching the channels and on the crunch and gain settings there is some sound but it's very quiet and distorted. It's nowhere near loud enough to cause any problems though. Craig Quote Link to comment Share on other sites More sharing options...
zolko60 Posted December 16, 2018 Share Posted December 16, 2018 I would not call it "faulty". It is probably bad design, users usually do not pay attention to. If H&K claim then can "replicate this behavior", it sounds they do not want to be responsible. There are no norms what that bleed should be. Quote Link to comment Share on other sites More sharing options...
ernsttore Posted December 16, 2018 Author Share Posted December 16, 2018 Thanks for the input, seams like you Craig have the same issue but maybe not as severe as mine I’ll think.... i play mostly at low volume so this a big problem, and increasing the volume on the amp just make it worse... Maybe the right word is a “bad design” and they just excuse themselves with some undefined reasons...Have now contacted H&K directly and are curious to hear what they have to say about this issue, but I’m afraid that i get the same answer that Thomann got from them! Asked Thomann if they could test this on a another TubeMeister deluxe 40, but they told me that they did not have any there to test! hmmm strange.....? Quote Link to comment Share on other sites More sharing options...
CraigGT Posted December 16, 2018 Share Posted December 16, 2018 Mine is possibly the norm and in no way could it be a problem so I guess yours must be worse. Have a listen to the clip recorded from the redbox out on the crunch channel. The first chord is with the loop off and the 2nd at about 8 seconds is with it turned on but it is barely audible. Craig H&K.mp3 Quote Link to comment Share on other sites More sharing options...
ernsttore Posted December 16, 2018 Author Share Posted December 16, 2018 Yes yours is barely audible, made a clip from mine in front of my cabinet, (crunch channel) first the loop off then on, and as you can hear it has more soundbleed although my guitarstrings are a bit present the bleed is more severe... 0F50211A-6FA9-41CA-B22E-5211ECC3FAAC.MP4 Quote Link to comment Share on other sites More sharing options...
CraigGT Posted December 16, 2018 Share Posted December 16, 2018 Yes that's worse than mine, I'd send both clips to H&K Quote Link to comment Share on other sites More sharing options...
ernsttore Posted December 18, 2018 Author Share Posted December 18, 2018 Have sendt them some clips and waiting for an answer...... Quote Link to comment Share on other sites More sharing options...
