Helix > iMac > AirPods
ch4920
You would have to have bluetooth from the Helix headphone output to your Air Pods. Unfortunately bluetooth is not very good for monitoring purposes because it is not an immediate sound and you will feel very quickly disconnected from the instrument. Just get some wired headphones and connect it to the headphone out on the Helix and use the Helix as your soundcard.
You're not giving us a lot of information here....
If you can get the mix you want from the Helix Headphone jack, plug in a Bluetooth transmitter and pair it to the AirPods. Easy.
You might be able to get the audio from the Helix headphone out to your Apple device (iPhone?) using the camera kit, thereby using the iThingy as Bluetooth transmitter.
However, unless Apple has performed a major bluetooth miracle, you're going to get a LOT of latency.
Good Luck!
