HelixMan Posted February 5, 2019 Share Posted February 5, 2019 I was wondering if anyone has seen this: I copied my IR's into the IR list in Helix Edit and they show in the list but I can't assign them to their preset IR blocks. I used both import from file & drag n drop - same result. I noticed the font is dull compared to the 1 and only IR that would show up in the preset assign list. Thot I must be missing something - pilots guide was no help. Thanks! Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted February 5, 2019 Share Posted February 5, 2019 If they show in your IR list then you simply add an IR block of either 1024 or 2048 size. Then with that block selected you can use the left most dial under the display screen to select which IR you want applied from the list. Quote Link to comment Share on other sites More sharing options...
HelixMan Posted February 5, 2019 Author Share Posted February 5, 2019 Right - that's how it's supposed to work. The problem is the IR will not assign to the block for some reason. I did a full reset after that last update and had to re-import everything. Presets - no problem. IR's look like they import but when I assign to the IR block they won't take. The left/right slider shows only 1 IR even though the IR list at left shows they're all imported. The 1 IR is brighter than the rest in the IR list. Quote Link to comment Share on other sites More sharing options...
dafrankum Posted February 6, 2019 Share Posted February 6, 2019 I too have the same problem. And getting a code 8216. Quote Link to comment Share on other sites More sharing options...
slowfinger33 Posted February 6, 2019 Share Posted February 6, 2019 Where are you sourcing the IRs from? I had this happen when I accidentally used some IRs that were meant for a different modeler (ie: Axe-Fx, Kemper, etc). The "incorrect" IRs loaded into the Helix just fine, but when assigning them to a block, it wouldn't work. Once I used a Helix compatible IR, it worked just fine. Quote Link to comment Share on other sites More sharing options...
HelixMan Posted February 6, 2019 Author Share Posted February 6, 2019 Mine are from Greg DeLuune made for Helix. A lot of guys on this forum have his IR's. They worked fine until I did that last update and did a reset. I've been doing updates all along since I got one of the 1st units in Oct 2015. But first time I did a factory reset. Maybe should not have done that. Quote Link to comment Share on other sites More sharing options...
phil_m Posted February 6, 2019 Share Posted February 6, 2019 Are you running the latest version of HX Edit? Many of these types of problems happen because people install the latest firmware but forget to download and install the latest version of HX Edit. 1 Quote Link to comment Share on other sites More sharing options...
shortspecialbus Posted February 6, 2019 Share Posted February 6, 2019 For what it's worth, I bought and installed a bunch of Greg's patches and IRs yesterday evening without any trouble, using latest HX Edit and 2.71 firmware, so at the very least it's not a universal problem with people who recently purchased some of his IRs. Quote Link to comment Share on other sites More sharing options...
HelixMan Posted February 7, 2019 Author Share Posted February 7, 2019 I have not done 2.71 yet - 1 behind. I'll try that and see if the IR problem is fixed. I always read the instruction and fixes and follow the steps pretty close. I'll report back on this thread when I get it updated - make sure it's the latest driver/edit/firmware. Not gonna do a total reset again tho... Quote Link to comment Share on other sites More sharing options...
