Thark Posted February 15, 2019 Share Posted February 15, 2019 Hi all. I have two JTV59's which I love playing and which are both loaded up with Arislaf's "Realistic Bundle" (https://www.vguitarforums.com/smf/index.php?topic=24065.0). They pretty much do it all for me but there is one minor irritation ... changing strings. It's pretty tough to slot the strings in the bridge and then wind them on the tuning machine without having the string fall out of the bridge. There's a simple solution to this though. A piece of tape holds the strings in nicely until they can be wound up to pitch. 1 Quote Link to comment Share on other sites More sharing options...
cbrillow Posted February 15, 2019 Share Posted February 15, 2019 Decent tip, thanks. I usually just change strings one at a time, though, which lets me keep the neck fairly consistently tensioned. Don't know if this is generally recommended or not, it's just the way I've done it for years... Quote Link to comment Share on other sites More sharing options...
Thark Posted February 16, 2019 Author Share Posted February 16, 2019 5 hours ago, cbrillow said: Decent tip, thanks. I usually just change strings one at a time, though, which lets me keep the neck fairly consistently tensioned. Don't know if this is generally recommended or not, it's just the way I've done it for years... Yes, this is the way that I normally do it as well. However, this time I was putting a set of locking Grovers onto the guitar and had all the strings off. Quote Link to comment Share on other sites More sharing options...
jerseyboy Posted February 16, 2019 Share Posted February 16, 2019 I solved this annoyance using locking tuners. About $60. Pull the strings hand taught lock em in place so they stay in the slots. Hipshot fit nicely and they're better than stock Korean JTV59 tuners. 1 Quote Link to comment Share on other sites More sharing options...
ginster Posted February 16, 2019 Share Posted February 16, 2019 19 hours ago, cbrillow said: Decent tip, thanks. I usually just change strings one at a time, though, which lets me keep the neck fairly consistently tensioned. Don't know if this is generally recommended or not, it's just the way I've done it for years... A decent guitar neck should not be in trouble or harmed being without tension while changing 6 strings not one at a time! That is what I think. 1 Quote Link to comment Share on other sites More sharing options...
jerseyboy Posted February 16, 2019 Share Posted February 16, 2019 Agree with Gin normal string tension and/or no tension makes no difference to a good neck. Unique to Variax legit reason to change 1-3 strings at a time is to minimize movement of the pickup saddles. Remember, there’s small signal wire attached to each bridge saddle and bridge assembly. Seems best to avoid any excess movement of that wiring. On the few occasions removing all strings on an old 500 will prefer to tape the saddles down in order to minimize movement while the strings are removed. JTV59 bridge is much less prone to individual saddle movement but do take care of the wiring from bridge. Quote Link to comment Share on other sites More sharing options...
Thark Posted February 16, 2019 Author Share Posted February 16, 2019 Agree with Gin and Jersyboy. There is no reason to worry about having no strings on the neck, at least for a short period of time. For a longer time you might want to straighten the neck with a truss rod ajustment and then re-set the relief after the new strings are on. A couple of reasons for removing all strings: oiling the fretboard to prevent cracking from excessive dryness (it’s *really* dry where I live, especially in the winter), leveling and crowning frets. I do all of my own guitar maintenance and most repairs and upgrades. I have so many instruments that it would cost a pile to have someone else do it ... and it’s kind of fun. Also, you know for sure that the work has been done the way you want it. 1 Quote Link to comment Share on other sites More sharing options...
cbrillow Posted February 16, 2019 Share Posted February 16, 2019 Quote Agree with Gin normal string tension and/or no tension makes no difference to a good neck. Basically, I agree with this, too. I do it one-at-a-time more out of habit than fear that something will get messed up. Plus, if I changed the way I do it now, I'd have to come up with some other silly habit, like changing the stings in the same order every time. And then I'd have to remember the order that I used the NEXT TIME I changed strings... At my age, the less I have to remember, the better... 1 1 Quote Link to comment Share on other sites More sharing options...
