rayberne2 Posted November 29, 2013 Share Posted November 29, 2013 DOES ANYONE KNOW HOW TO USE A FOOTSWITCH TO TURN THE AMP DRIVE UP OR DOWN Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 29, 2013 Share Posted November 29, 2013 You can't assign different parameters to footswitches like that, but you can assign almost any parameter to be controlled by one of the expression pedals. Quote Link to comment Share on other sites More sharing options...
Dutchguitarist Posted November 29, 2013 Share Posted November 29, 2013 You cannot use footswitched to do that but as far as I know you can control the amp's drive knob with the expression pedal. Simply use the controllers section of HD edit: select the amp, choose drive as parameter en set the desired min and max value. 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 29, 2013 Share Posted November 29, 2013 If you only want to switch between two different Amp Drive settings you could use a footswitch to do this by creating two different presets, and set your device to FS Mode = ABCD. Set up the presets so that the only difference is the Amp Drive setting; then use the footswitch to switch between the presets. But if you want to control the Amp Drive setting within a range of Max/Min values then you must use an expression pedal as described above. 1 Quote Link to comment Share on other sites More sharing options...
GTLazer Posted November 29, 2013 Share Posted November 29, 2013 You can assign more than one parameter to the pedal as well, so you could have a sweep of the pedal that increases the drive but also reduces the channel volume to keep the overall level similar. 1 Quote Link to comment Share on other sites More sharing options...
alexisltd Posted November 29, 2013 Share Posted November 29, 2013 to the OP check this http://www.youtube.c...h?v=U0sLDW1yvGU and I think this can be achieved using an external footswitch like a boss fs-5L in PEDAL 2 jack Quote Link to comment Share on other sites More sharing options...
bvaladez74 Posted November 29, 2013 Share Posted November 29, 2013 Just assign an OD pedal to a switch. Quote Link to comment Share on other sites More sharing options...
