ChaserHUN Posted December 14, 2013 Share Posted December 14, 2013 I wan' to buy an 500X because I had it with carring a heavy amp had and tap dancing on my pedal board. I have a 212 cab with V30s. If I use the POD HD500X with a power amp to power my cab, should I turn off the cab/mic simulation? Can you plug 2 guitars in the POD HD500X? For example I want to put a piezo bridge in my guitar and it would be cool if it could handle both outputs. Quote Link to comment Share on other sites More sharing options...
rootmusic Posted December 14, 2013 Share Posted December 14, 2013 There are master settings for what you are plugged into. There is one for plugging into a power amp. I used to use twin sounds. As long as your guitar has two outputs plug guitar into guitar in and Piezo into Aux in and you can route these to independant signal paths. Quote Link to comment Share on other sites More sharing options...
ChaserHUN Posted December 14, 2013 Author Share Posted December 14, 2013 Okay, are there any vidoes on that? I1ve red somewhere in the forums here that the aux in doesn't sound that good. Also if I want a realy acoustic sound would my cab need piezo speakers too? If I am at a venue where I wouldn't need my cab because the PA system is that good, can I turn on the cab/mic simulation fast or do I have to make new presets? Quote Link to comment Share on other sites More sharing options...
joel_brown Posted December 14, 2013 Share Posted December 14, 2013 I use the PODHD with the Amp Pre models and cab/mic simulation into a power amp and cab. But that doesn't mean it's the best way for you. Some experimentation is required. Your second question: I'd suggest making a seperate preset with cab and mic sim turned on. It's easier and if you do forget to turn them on you can quickly switch to the differant preset. Quote Link to comment Share on other sites More sharing options...
AParedes Posted December 15, 2013 Share Posted December 15, 2013 1: if you are using the POD HD > Power amp . 2x12 cabinet: I would reccomend starting with the Pre amp models and turn off the cab modeling. Some people find too much "color" if you don't... but whatever sounds best to your ears is what's "right". 2: Yes, you can plug two inputs in simultaniously, as well as route each differently depending on your needs. 3: there are eight setlists on the HD500/X, I tend to have similar presets with different schemes depending on the situation. i.e.: Setlist 1: direct recording Setlist 2: going to powered speaker (full amp/speaker modeling) Setlist 3: going to a tube power amp and voiced speakers (pre-amps, no cab modeling) Setlist 4: Dream Rig this way I can switch as needed quickly if I need to change my rig without trying to write presets in the middle of a performance. Quote Link to comment Share on other sites More sharing options...
gckelloch Posted December 15, 2013 Share Posted December 15, 2013 The manuals will instruct you on how to operate the Pod HD500X. If you really want to understand how to get good tones from the Pod HD series, you should start reading this guide:http://foobazaar.com/podhd/toneGuide/ Quote Link to comment Share on other sites More sharing options...
