mtmartin71 Posted December 26, 2013 Share Posted December 26, 2013 Just curious if anyone else out there has experienced a situation where the Sonic Port 1/4" out and headphone out are really low, to the point they can't be amplified without a lot of noise. I confirmed the output is fine within the iPad itself because I plugged in headphones to the iPad, which is turned up all the way, and it worked great with the SW controls for volume. However, if I try to go out of the Sonic Port to headphones or to my Forte Focusrite, I can't VERY limited signal. I also get a weird problem where the reverb is "slurred" or messed up in Mobile Port. Turning on some effects brings the volume up. It's weird because another app, BIAS, has the same issue as far as low volume out through the device. Anyhow, before I open a ticket I thought I'd lean on some knowledge of the user base. 1 Quote Link to comment Share on other sites More sharing options...
sirhc1956 Posted February 27, 2014 Share Posted February 27, 2014 I just got my Sonic Port today and have come here because of the very same problem. Connecting the line out to my bass amp, the sound level is very low, even if I take everything out of the signal chain. The output to the headphone jack is non-existent. I'm using Positive Grid's JamUp program. Sounds fine if I plug headphones directly into my iPad or iPhone (tried both), but little or no analog output from the Sonic Port itself. I suspect a defective unit, but any advice or insight is appreciated. Quote Link to comment Share on other sites More sharing options...
BabyHuey Posted March 3, 2014 Share Posted March 3, 2014 I am having a similar problem. Very low levels from the guitar (on both the iPad headphone jack and headphone out on the Sonic Port). If I turn up the ipad volume to almost full I get to an ALMOST usuable level ... but then all other sounds from the iPad are at a ear splitting level. Is there a way to adjust the gain on the sonic port? I have tried both the Mobile POD app and JamUP Pro (both with the volume slider maxed) Tried two guitars (a regular strat and an active bass) Tried two sets of headphones (not an issue anyway, since there is plenty of volume in other apps) Tried two patch cables (they both work fine to my amp) Ipad Air, IOS 7.0.6 Quote Link to comment Share on other sites More sharing options...
ridethatbike Posted March 3, 2014 Share Posted March 3, 2014 I'm in the same boat. iPad Air-->sonicport-->headphone or roland cube or real tube amp. The output levels are so low, that only the real tube amp can provide any decent volume. Kind of stinks, I'm starting to look at Guitar Center's return policy... Quote Link to comment Share on other sites More sharing options...
BabyHuey Posted March 4, 2014 Share Posted March 4, 2014 I opened a ticket for this problem. No reply yet. The web page says to expect a response within 3 business days. Quote Link to comment Share on other sites More sharing options...
BabyHuey Posted March 4, 2014 Share Posted March 4, 2014 Well I got a response. The tech suggests adding compressor, eq and turn up the amp sim volume. That doesn't fix the problem for me. I only want to hear the sound of my instrument, no amp, no effects. I have sent a reply.... Quote Link to comment Share on other sites More sharing options...
plyall Posted March 11, 2014 Share Posted March 11, 2014 I am here with the same issue - low volume (extremely) out of the Headphone Out 1/8" port on the Sonic Port. I have not yet tested the 1/4" output. I just opened a ticket as well. My iPad's headphone jack is roughly 10x louder than the headphone jack in the Sonic Port. This just cannot be correct. Adding a compressor and turning the amp up (as stated in an earlier post) is a simply ridiculous answer. I bought this unit BECAUSE it had its own line/phones outputs, and other competing interfaces don't. If this turns out to be a class problem, I would have been better off with a competitor's unit (Apogee, etc.). If anybody figures out a fix, will you please post it here? Thanks! Quote Link to comment Share on other sites More sharing options...
user-1814307 Posted March 28, 2015 Share Posted March 28, 2015 I am having a similar problem. Very low levels from the guitar (on both the iPad headphone jack and headphone out on the Sonic Port). If I turn up the ipad volume to almost full I get to an ALMOST usuable level ... but then all other sounds from the iPad are at a ear splitting level. Is there a way to adjust the gain on the sonic port? I have tried both the Mobile POD app and JamUP Pro (both with the volume slider maxed) Tried two guitars (a regular strat and an active bass) Tried two sets of headphones (not an issue anyway, since there is plenty of volume in other apps) Tried two patch cables (they both work fine to my amp) Ipad Air, IOS 7.0.6 I'm having the exact same problem. Have tried different cables, guitars, mobile pod and jamup. I have a 100 watt amp at 8 and can hear the acoustic sound of the stings louder than the amp. I, too, pitched the because of the 1/4 inch out. What's the point of the device if you can't use it to play? Tom Quote Link to comment Share on other sites More sharing options...
ArneLine6 Posted March 30, 2015 Share Posted March 30, 2015 Just to make sure: The output volume of the sonic port devices ic controlled by the iPhones volume buttons. Have you tried to turn up the iPhones volume? 1 Quote Link to comment Share on other sites More sharing options...
alexxbrito Posted May 10, 2015 Share Posted May 10, 2015 Unfortunately Sonic Port interface stopped working after the upgrade to IOS 8. Quote Link to comment Share on other sites More sharing options...
ArneLine6 Posted May 11, 2015 Share Posted May 11, 2015 It is possible that you need to give the app access to the microphone in the iOS settings. Settings> Privacy> Microphone> (app) Quote Link to comment Share on other sites More sharing options...
alexxbrito Posted May 26, 2015 Share Posted May 26, 2015 Thanks for the answer. Unfortunately the problem continues, the IOS 8 is not recognizing the Sonic Port. Quote Link to comment Share on other sites More sharing options...
stevekc Posted June 24, 2015 Share Posted June 24, 2015 What is your IOS device? Here my Sonic port VX works great with iPhone 6 Plus and iPad AIR = both are using IOS 8.1.3 Remember the 1/4" Outputs on Sonic port are TRS Balanced ,and these work best when using a 1/4" TRS to XLR Male cable straight into a PA Quote Link to comment Share on other sites More sharing options...
barkerm Posted October 25, 2015 Share Posted October 25, 2015 I am also having output level issues with the Sonic Port VX. I am using an iPad Air2 with Mobil Pod. The iPad is receiving the audio at sufficient levels (from an Ovation Acoustic-Electric guitar) - can even turn up the guitar and iPad controls enough to cause distortion, so certainly not a problem with the Sonic Port output to the iPad interface. But what comes out of the balanced L and R outputs aren't enough to drive my JBL powered monitors set at -10dBV sensitivity. Other audio equipment drives the monitors fine. I am using TRS to XLR cable. Anyone know what the output level is supposed to be from the Sonic Port? Quote Link to comment Share on other sites More sharing options...
rkhiii Posted July 13, 2016 Share Posted July 13, 2016 My Apple buds seem to sound OK thru the SonicPort VX headphone port but when using my AKG K-240S or Beyerdynamic DT770 80 OHM phones, the signal is very distorted. Was it ever determined whether this is a SonicPort issue that Line 6 needs to address via a software or hardware fix before I either exchange my Beyer's for a different OHM version or punt and buy an Apogee One? Thanks, --R Quote Link to comment Share on other sites More sharing options...
