Helix Hx Effects Firmware update
rubjis
I recently updated to 2.8.1 firmware. I did not back up my patches, as I had not created any patches to back up before updating the firmware. Does anyone have a copy of the stock patch that you exported from HX Edit? I still have the stock patches, but none of the names.
Thanks!
Bill
Thanks!
Bill
Hi Bill,
I think that the factory reset instruction above were given in error. Your HXFX doesn’t have FS7 & FS8, that’s for the floor unit Helix and LT, and it’s an easy mistake to make.
Here ya go!
HX Effects: Turn unit off and then turn back on. Hold Footswitch 6 and Tap throughout the boot process, until you see that your factory presets are loading. If you run into any trouble with a failed update or your unit will not boot up, try powering on while holding the right arrow ">" This will put the unit into update mode and you can re-install the latest firmware from there.
Hope this helps.
