tourultimate Posted July 28, 2019 Share Posted July 28, 2019 With 2.8 the transparent tap tempo works when manually changing tempo by tapping. However when tempo is per snapshot, changing snapshots causes the warble with the time based effects. Unfortunately, this is issue affects me because I am on stage several times a month and transitions between songs is now difficult with this bug. Has anybody else experienced this? Quote Link to comment Share on other sites More sharing options...
tourultimate Posted July 29, 2019 Author Share Posted July 29, 2019 I submitted a bug report to line 6 and also added the bug in the sticky thread. Is nobody else experiencing this issue? Quote Link to comment Share on other sites More sharing options...
codamedia Posted July 29, 2019 Share Posted July 29, 2019 That's odd.... I thought this was suppose to be one of the features/fixes with 2.8.... That behavior has been there all along, but 2.8 was suppose to make it truly transparent. From the 2.8 release notes... The Global Settings > Preferences > Tap Tempo Pitch (Authentic, Transparent) setting now also affects tempo changes taking place across snapshot changes, not just when pressing the TAP switch Quote Link to comment Share on other sites More sharing options...
duncann Posted July 29, 2019 Share Posted July 29, 2019 2 hours ago, tourultimate said: I submitted a bug report to line 6 and also added the bug in the sticky thread. Is nobody else experiencing this issue? I tried on a new preset and it appears to work correctly. Quote Link to comment Share on other sites More sharing options...
tourultimate Posted July 29, 2019 Author Share Posted July 29, 2019 19 minutes ago, codamedia said: That's odd.... I thought this was suppose to be one of the features/fixes with 2.8.... That behavior has been there all along, but 2.8 was suppose to make it truly transparent. From the 2.8 release notes... The Global Settings > Preferences > Tap Tempo Pitch (Authentic, Transparent) setting now also affects tempo changes taking place across snapshot changes, not just when pressing the TAP switch Well it’s much weirder that I’ve never noticed it before the update. Quote Link to comment Share on other sites More sharing options...
tourultimate Posted July 29, 2019 Author Share Posted July 29, 2019 5 minutes ago, duncann said: I tried on a new preset and it appears to work correctly. Maybe it has to do with the fact that I’m my case it’s not a brand new preset, but one that existed before the update to 2.8 Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 30, 2019 Share Posted July 30, 2019 Are you sure the setting is set to Transparent? The update resets your Global Settings, and Authentic is the default setting. Quote Link to comment Share on other sites More sharing options...
tourultimate Posted July 30, 2019 Author Share Posted July 30, 2019 23 minutes ago, phil_m said: Are you sure the setting is set to Transparent? The update resets your Global Settings, and Authentic is the default setting. Yes sir, I am sure. I’ve tried toggling the setting in global to “transparent” a few times to no avail. Quote Link to comment Share on other sites More sharing options...
tourultimate Posted October 2, 2019 Author Share Posted October 2, 2019 This has been fixed in 2.8.2! Thank you line 6!! Quote Link to comment Share on other sites More sharing options...
