lelandbowman3 Posted August 14, 2019 Share Posted August 14, 2019 Long story short, I've installed the drivers over and over, and I still get the "No Devices Detected". (Mac OS Mojave) I'm not sure if it's because the drivers aren't installing (yes, they're checked off on the system preferences) or what is going on. But this is just really infuriating. Please help? Quote Link to comment Share on other sites More sharing options...
cmelo Posted August 18, 2019 Share Posted August 18, 2019 I have the same problem and i can not solve it Quote Link to comment Share on other sites More sharing options...
tariqarien Posted August 20, 2019 Share Posted August 20, 2019 Had the same problem on both my Macbook and iMac. Solved it by de-installing every driver, plugin and whatsoever. After that I did the following: 1. Download latest version of drivers from the web. 2. Download latest version of License manager and login. 3. Download latest version of Line 6 Monkey. 4. Make sure every under Driver and Applications is green. Workbench is not necessary. 5. Download POD HD Pro X Edit. Here is the part where I did wrong. Make sure you download the 'X' version. Otherwise nothing will work. 6. Run Line 6 Monkey again. Make sure everything is marked green now (Workbench still not necessary). In the attachment I uploaded the current versions which got my Pro HD X running. Note: I'm running Mojave 10.14.5. Line 6 Monkey doesn't always have the latest version ready. It's best to install drivers and applications by hand through the download-page on line6.com. For example I've got already a newer version of Workbench but L6Monkey says the newest version is 2.14. But buggy if you ask me. Goodluck guys! Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted August 20, 2019 Share Posted August 20, 2019 On 8/20/2019 at 5:02 AM, tariqarien said: 5. Download POD HD Pro X Edit. Here is the part where I did wrong. Make sure you download the 'X' version. Otherwise nothing will work. I'll take it a step further, and say: No matter what unit you have, make sure you download the correct version. Otherwise, nothing will work. Quote Link to comment Share on other sites More sharing options...
tariqarien Posted August 21, 2019 Share Posted August 21, 2019 13 hours ago, pianoguyy said: I'll take it a step further, and say: Thanks, this additional information is really, really helpful! Quote Link to comment Share on other sites More sharing options...
digitalPimple Posted May 26, 2020 Share Posted May 26, 2020 Monkey STILL not working on Catilina and nothing can connect on my side. My purchase is completly usless... Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 26, 2020 Share Posted May 26, 2020 41 minutes ago, digitalPimple said: Monkey STILL not working on Catilina and nothing can connect on my side. My purchase is completly usless... Monkey isn’t compatible with Catalina given that it’s 32-bit. But what are you trying to do? Is your HD running the latest firmware? You don’t need Monkey to download and install the latest drivers and editor. Quote Link to comment Share on other sites More sharing options...
digitalPimple Posted May 26, 2020 Share Posted May 26, 2020 I downloaded the drivers and the editor and it will not connect through USB as it did in the past. It's been boxed for 5 months. Whenever I open up editor or any Line 6 Program it can not see the unit at all. Quote Link to comment Share on other sites More sharing options...
digitalPimple Posted May 26, 2020 Share Posted May 26, 2020 Line 6 updater just says select a product and no product is available. Quote Link to comment Share on other sites More sharing options...
