stevieRay999 0 Posted September 8, 2019 Hello from Germany! I just get my JTV-69 out of my bunch of various guitars and wonna have fun... As already mentioned in the title - when I turn off the electric way (playing with normal PUs) the tone poti has no effect, everything sounds "dull/dark" - no brightness. If I turn on the modelling the tone poti works fine. I really am not sure if this was the normal function when I recently used the Variax but... certainly I would heard it. Does anybody have an idea or even better a solution? I cannot imagine, that this little passive component can be broken because it works fine with different switch settings. Do I have a chance to fix it by myself when I open the guitar? Thanks so much and best regards, Wilfrid Quote Share this post Link to post Share on other sites
psarkissian 354 Posted September 9, 2019 Register the guitar in your account, then log a Support Ticket. It will have to be serviced by an authorized service technician, who knows the product. Not something to repair yourself if it needs a part. It's not an off-the-shelf part for it. Quote Share this post Link to post Share on other sites
line-6-user 9 Posted September 10, 2019 In my case, I have the tone pot on my 69 a bit scratchy, moving it a few times it clears it and operates without any noise. Can it be cleaned by the user or does it need to be replaced? Quote Share this post Link to post Share on other sites
psarkissian 354 Posted September 10, 2019 Make certain the pot is not loose. If it is, carefully pull off the knob, tighten down the retainer nut, 1/4" hex socket, until it is good and snug. Not too tight, don't want to strip any threads. For cleaning pots and faders. Quote Share this post Link to post Share on other sites
line-6-user 9 Posted September 11, 2019 Thanks for that, I'll be trying it as soon as I get the cleaner. Quote Share this post Link to post Share on other sites
