frac82 Posted September 25, 2019 Share Posted September 25, 2019 scenario: guitar -> HD400 to DT25 via L6 Link -> 2x 112 cabs. if I plug 2 cabinets on a DT25 , 12" 8 Ohm each, will I either hear a "dual mono" or a "full stereo" sound? and, above all, what about effects like the stereo delay? Quote Link to comment Share on other sites More sharing options...
jakeman19 Posted October 7, 2019 Share Posted October 7, 2019 Frac82, "dual mono" as it would be summed to mono as the DT25 is a mono amp. Jd Quote Link to comment Share on other sites More sharing options...
frac82 Posted October 19, 2019 Author Share Posted October 19, 2019 thank you very much jakeman19, sorry for late reply. so full stereo delay means 2x DT heads... right? just two more questions about L6 link scenario: I have to switch the amp model menu on preamp (rather than full), do I? which Output Mode - Live Options do I have to chose (studio direct, combo/ stack front or combo/ stack power amp)? thanks Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted October 19, 2019 Share Posted October 19, 2019 Yes, you won’t get stereo unless you use two amps. 1. When using a DT you are using the power amp in the DT so you can use preamp models from the pod. However, use your ears and just use what sounds good to you. 2. I tend to use combo/stack power amp (emulating going in the fx loop) but again, see what sounds best to you. 3. Have fun! Quote Link to comment Share on other sites More sharing options...
