peyal
Hi everyone,
I setup a new home working station a couple of days ago. Here is a sketch of the station:
More details about it: (not sure if important)
My NUC is brand new, the monitors are m-audio and TV is LG.
All of the power cables are with 3 pins, and the power adapter for my PC has 3 pins also.
The problem is that I keep hearing these static noises as soon as I plug in the USB cable that connects the Helix and the PC.
Here is a link to a recording of these noises:
https://vocaroo.com/i/s1dDVqIoVI7t
As far as my research on the internet goes, I suspect it has something to do with ground loop.
One thing that really stood out while troubleshooting is that when I replace my NUC with a laptop that I have, the noise stops.
This solution is out of the equation, as the laptop is inferior in performance compared to the NUC.
Other things that I already tried with no success:
Replacing the USB cable, the PLs, another wall socket for the helix or the monitors, replacing the power cable of the computer power adapter,
shutting down the router or the Helix (the noise persists even if the Helix is turned off).
If anyone has an advice, a solution or other ways to troubleshoot the problem it will be much appreciated.
Thanks,
Eyal
This sounds to me more like a shielding or grounding issue on the  NUC unit itself.  Normally ground loops are caused by a difference in grounding between two devices on two different wall sockets that are on different circuits causing that difference to be sent through other cables that are connecting the two devices trying to reconcile the differences, and it would be present with your laptop as well.  If the NUC is new you might try exchanging it for a new one as that may simply be a defect in that unit.
Alternatively you could try the Ebtech Hum Eliminator, but they advise against connecting that through a power strip, but in my experience it still seems to work when connected that way.
12 minutes ago, jbuhajla said:
I get static "pops" when connected to my laptop via USB. It hasn't bothered me that much, but I have considered using one of these isolators on the USB port to see if goes away.
https://www.amazon.com/Audio-iDefender3-0-Ground-Loop-Eliminator/dp/B01N3XKOLG
Since I solved the problem with an $18 passive stereo hum eliminator, I can't see spending $49 on this gizmo, but if you try it and it works, do report back, it looks interesting and I hadn't seen it before!
  • 3 weeks later...
Hi everyone,
First of all, I want to thank everybody that suggested something that could have helped me.
Second, I managed to solve my problem so I wanted to update the post in case anyone ever faces this kind of problem.
My monitors have an XLR input, so I just bought 2 good XLR cables and connected the Helix using them.
The sound still persists, but it is BARELY audible. You have to get your ear really close to the monitors in order to hear the sound, and even this close it is very difficult to notice it.
So for everyone reading this post having this sound problem - If you can, connect your monitors and Helix using XLR cables and not PLs.
