AndyDobbs123 Posted October 22, 2019 Share Posted October 22, 2019 The tap tempo on my hx effects and the flashing red light don't seem to be synchronised. For example, if I set the tempo to 60 bpm, the delay is exactly in time with my watch but the red flashing light is is faster than 60 flashes per minute. Is this normal? Is there anyway I can fix this? I'd like to use the light as a guide but as it is, it's kind of useless. Quote Link to comment Share on other sites More sharing options...
886343 Posted October 22, 2019 Share Posted October 22, 2019 I am having the exact same issue! I posted this the other day - https://line6.com/support/topic/52057-hx-fx-tap-tempo-flashing-light/ Quote Link to comment Share on other sites More sharing options...
phil_m Posted October 22, 2019 Share Posted October 22, 2019 Are you running the latest firmware? This came up a long time ago, but I'm pretty sure it was dealt with in a firmware update. Even after that , though, the tap tempo LED and the actual tempo are not running off the same clock, so they may drift a bit over time. Quote Link to comment Share on other sites More sharing options...
codamedia Posted October 22, 2019 Share Posted October 22, 2019 This took some getting used to after using an X3 and HD500 for many years prior to the Helix. The Helix doesn't tie the light to the same clock so it will not stay in sync. Certainly not a deal breaker for me, but it does seem like such a silly oversight. Quote Link to comment Share on other sites More sharing options...
