robmlisanti Posted January 23, 2014 Share Posted January 23, 2014 Any suggestions on how I can get a BIG sound with my POD HD desktop 2 amps? Mixer settings? Chorus effects? etc.... Thanks! Quote Link to comment Share on other sites More sharing options...
duncann Posted January 23, 2014 Share Posted January 23, 2014 Here's a preset that's for the HD500 that might be something of what you're looking for. DBack-1-7-4-39.zip Quote Link to comment Share on other sites More sharing options...
brian6string Posted January 24, 2014 Share Posted January 24, 2014 One way is to take the same amp model x2. Mix both to the center, but use different mic combinations on each. My favorite is SM57, one on-axis, one off-axis. Another way is to mix and match one clean-ish amp with one more distorted, hard pan these L-R. Suggest AC30 + Dual Rectifier. For this arrangement, I put a digital delay in one of the signal paths, 100% wet with a very short delay time (24ms or so). Gives you a little bit of separation between the two signals. 1 Quote Link to comment Share on other sites More sharing options...
StephenSLR Posted January 28, 2014 Share Posted January 28, 2014 Here's a preset that's for the HD500 that might be something of what you're looking for. Can you describe what's in that preset? s Quote Link to comment Share on other sites More sharing options...
innovine Posted January 28, 2014 Share Posted January 28, 2014 Most big sounds come from doubling or quad tracking the guitars. Are you doing that? 1 1 Quote Link to comment Share on other sites More sharing options...
GTLazer Posted January 28, 2014 Share Posted January 28, 2014 I've had better results from 2 of the same amp with 2 different cabs, rather than two different amps, although obviously ymmv. As ever, meambobbo's guide contains a wealth of information on the subject. Quote Link to comment Share on other sites More sharing options...
duncann Posted January 28, 2014 Share Posted January 28, 2014 Here's what's in the preset. FX, Amp Amp Parameter, Amp Cab Parameters, Mixer: 1 Quote Link to comment Share on other sites More sharing options...
