johnnyvlee Posted December 14, 2019 Share Posted December 14, 2019 Ok, so I am a noob to Helix, but not a complete noob. I'm a software developer, good with tech. But, I'm seeing some weird behavior with editing snapshots in HX Edit that doesn't seem to match up with how they are supposed to work. Before I dig into this, let me say my global preferences are set to discard changes to snapshots. So, I have to save them or they get discarded. So I have this lead patch, and I want that exact setup for Snapshot 2, but I want to customize Snapshot 1 and save it as a more dialed down sound. Basically 1=rhythm, 2=lead. I bypass a couple of effects, and I make some significant tweaks to parameters on the 10-band EQ. I save the patch (thus saving my snapshot changes), then switch to Snapshot 2. When I do that, the bypassed pedals are no longer bypassed, which is what you would expect. However, the EQ parameters stay the same. They don't bounce back to Snapshot 2 settings. If I now edit them again, save the patch, and go back to Snap1, they are once again NOT restored to Snap1 EQ settings. What gives here? My understanding is it should restore the individual parameters on each block? Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 14, 2019 Share Posted December 14, 2019 For parameters to be recalled via snapshot changes, they have to be assigned to a controller. If you only want them to change via snapshots and not have other real-time control, you’d assign them to the Snapshot Controller. In HX Edit, you can right click on the parameter to assign a controller to it. When the menu of available controlllers pops up, just select Snapshot. On the unit itself, push and turn the knob for the parameter. You’ll see brackets appear around the value. Quote Link to comment Share on other sites More sharing options...
johnnyvlee Posted December 14, 2019 Author Share Posted December 14, 2019 THAT was the connection I wasn't making. I had seen demos with the brackets thing, but had not seen anyone state what you just said clearly. Thanks for the assist! Quote Link to comment Share on other sites More sharing options...
