Connection interrupted
Regboot13
Since I have upgraded to 2.8x I have had this issue often. HXEdit loses connection to the device. I have also encountered the unit freezing up but not nearly as often as the connection interruption.  Sometimes I need to reboot to fix and sometimes just turning Helix off then on. I am on Windows 10.
  • 10 months later...
My HX Edit won't stay connected for more than 5 minutes. Constantly disconnecting and showing the message "connection interrupted". Reconnect almost always works. I'm interested in your post because you (prudenjim) are on Windows, and I've having the issue on a Mac (Big Sur). I only noticed it happening this frequently after upgrading to big Sur but now I wonder if it's not related.
This thread is 10 months old and the issue was discussing the older v2.8x firmware and Windows 10.
It has been mentioned that Line 6 sent out an email telling customers to avoid updating to Big Sur until further notice, but as you are already in that situation I would suggest that you might need to zap the PRAM or NVRAM on your Mac.
Try this.
https://support.apple.com/en-us/HT204063
No guaranteed, but worth a shot as some stuff can get screwed up after an update.
Seems that Big Sur had lots of USB disconnect issues early on.
Hope this helps/makes sense.
  • 8 months later...
28 minutes ago, Desuuza said:
USB connection keeps dropping on HX Edit.
In the bottom right hand corner of your this page is a black dot containing a white circle and question mark. Click on it, then from under Common Product FAQ, click on the linked item marked "USB Connection Issues" and follow the instructions given.
  • Upvote 2
