Pufedu Posted January 26, 2020 Share Posted January 26, 2020 Hi! So, I have been seriously considering buying Helix LT from Thomann, since its under 900€ there. How ever, I have never used these amp modeling units before, and my understanding of them is pretty limited. So, my question is: How would I setup the Helix LT to be able to use headphones, and play along with Spotify tracks on my PC? Just to be super clear, i want to hear BOTH Helix and Spotify from my headphones at the same time (duh) I do have a Focusrite Scarlett Solo 2nd gen audio interface which I plug my headphones into when normally using my PC. So would I need to connect the Helix to the Focusrite? If so, should I connect it to the microphone, or instrument slot? Or will it be enough to just connect the Helix to my PC with the USB cable, and then plug headphones into the Helix? I live in an apartment, so being able to use headphones and play along to music that way is a "must have" feature for me. I have been using amp sim softwares like Bias Amp before, and with those I have just plugged my guitar into my pedalboard, and the pedalboard into my Focusrite interface and that's it. Thank you so much for your help! I am really looking forward to getting the Helix if what I described is possible with it. Quote Link to comment Share on other sites More sharing options...
themetallikid Posted January 26, 2020 Share Posted January 26, 2020 I simply connect USB cable between the 2 and use headphones when learning songs and jamming at home. If I want to 'move some air', i just run an XLR out to my powered wedge. I control the 'mix' by using the volume on Spotify/Laptop. I'll set my overall volume with the big knob for my guitar volume, then add in spotify as I like. 1 Quote Link to comment Share on other sites More sharing options...
Pufedu Posted January 26, 2020 Author Share Posted January 26, 2020 12 minutes ago, themetallikid said: I simply connect USB cable between the 2 and use headphones when learning songs and jamming at home. If I want to 'move some air', i just run an XLR out to my powered wedge. I control the 'mix' by using the volume on Spotify/Laptop. I'll set my overall volume with the big knob for my guitar volume, then add in spotify as I like. Wow! Wonderful, thanks for a quick response! Quote Link to comment Share on other sites More sharing options...
Pufedu Posted January 26, 2020 Author Share Posted January 26, 2020 16 minutes ago, themetallikid said: I simply connect USB cable between the 2 and use headphones when learning songs and jamming at home. If I want to 'move some air', i just run an XLR out to my powered wedge. I control the 'mix' by using the volume on Spotify/Laptop. I'll set my overall volume with the big knob for my guitar volume, then add in spotify as I like. Oh by the way, just to make sure; Do you connect your headphones to your PC or the Helix? I would imagine the Helix? Quote Link to comment Share on other sites More sharing options...
themetallikid Posted January 26, 2020 Share Posted January 26, 2020 yes the helix. I dont do any recording so Ive never listened through my laptop. either headphones or XLR and either the big knob or headphones knob (full Helix) to adjust my overall level. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 26, 2020 Share Posted January 26, 2020 The devil is in the details. If you use the Focusrite for recording, set the Focusrite as your soundcard in Windows, connect the LT and headphones to the Focusrite, and use the mix knob on the Focusrite. If you're using the LT for recording, set the LT as the soundcard in Windows, in Global Settings>Ins/Outs on the LT set "USB 1/2 Destination" to wherever the speakers are connected, set "Headphones Monitor Multi"and plug the headphones into the LT. In either case, use the Level on the app (YT, Spotify, whatever) to control the streaming level into the AI. Quote Link to comment Share on other sites More sharing options...
