DavidBurt Posted April 22, 2020 Share Posted April 22, 2020 Is there a separate procedure for updating Helix Native to 1.9? I've successfully updated Helix Floor to 2.9 following the instructions but Helix Native is still at 1.8. I don't see specific update information for Helix Native. The update procedure states that it is for Floor and Native. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 22, 2020 Share Posted April 22, 2020 You’re not doing anything wrong. You need to manually download and install Helix Native v1.90 from the Downloads section of this website. It is not done automatically because HX Native is a separate purchase/product. Not all Helix owners have Native, and vice-versa. Quote Link to comment Share on other sites More sharing options...
Slideguitar30 Posted April 22, 2020 Share Posted April 22, 2020 Hi All, After the update of firmeware 2.90, I see an anomaly in setlist #5 and crash of Helix LT. Your opinion please ; Thank you for your reply Regards Mike Quote Link to comment Share on other sites More sharing options...
DavidBurt Posted April 22, 2020 Author Share Posted April 22, 2020 1 hour ago, silverhead said: You’re not doing anything wrong. You need to manually download and install Helix Native v1.90 from the Downloads section of this website. It is not done automatically because HX Native is a separate purchase/product. Not all Helix owners have Native, and vice-versa. Thank you Sliverhead from an appreciative fellow Ontarion! Quote Link to comment Share on other sites More sharing options...
qwerty42 Posted April 22, 2020 Share Posted April 22, 2020 1 hour ago, Slideguitar30 said: Hi All, After the update of firmeware 2.90, I see an anomaly in setlist #5 and crash of Helix LT. Your opinion please ; Thank you for your reply Regards Mike That's not Helix LT, that's HX Edit connected to your LT. Did you update HX Edit to version 2.9, along with your Helix? If you disconnect the USB cable from your Helix, re-boot it, and look at the preset list on the LT itself (*not* your computer), are you seeing the same errors? Quote Link to comment Share on other sites More sharing options...
Slideguitar30 Posted April 23, 2020 Share Posted April 23, 2020 OK ! Thank you qwerty42 for your prompt response. As requested, I restarted the Helix LT ( disconnected from the PC ) and observed the same symptoms. Navigation on the setlist 5 up to the preset 09A ( empty ) and device crash ( black screen ) . Restart and always the same observation. I fear the worst !!! For info: Helix LT 2.90 / Hx Edit 2.90 - Windows 10 The other setlists seem to work correctly Regards Mike Quote Link to comment Share on other sites More sharing options...
Hillman1312 Posted April 23, 2020 Share Posted April 23, 2020 Looks like corrupted presets to me. See this thread for some inspiration and ways to resolve the issue . Quote Link to comment Share on other sites More sharing options...
Slideguitar30 Posted April 23, 2020 Share Posted April 23, 2020 Thank you Hillman1312 but in my case the setlist is empty ( no preset saved ) I observed this anomaly by accident ! Quote Link to comment Share on other sites More sharing options...
Slideguitar30 Posted April 24, 2020 Share Posted April 24, 2020 Hi all, Maybe I’m in the wrong place to expose my problem. Can you guide me? Regards Mike Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 24, 2020 Share Posted April 24, 2020 You are in the right place. It seems you have some sort of corruption with presets in Setlist 7, or setlist structure itself. You need to remove the corruption and the best way to do that is a factory reset. There are different options is performing a reset. The details for doing it on each Helix device are described here: Before resetting the device make sure to backup / export all your custom setlists that you want to restore later. (e.g. Blues, Rock, ...). I would start by choosing the reset option that just restores the factory setlists and leaves your IRs and Global Settings in place. Quote Link to comment Share on other sites More sharing options...
Slideguitar30 Posted April 25, 2020 Share Posted April 25, 2020 Hello Silverhead, First of all I must thank you for your answer and your valuable advice. I confirm your analysis, they are indeed presets or rather corrupted addresses. According to your methodology, I performed a system reset ( FS9/FS10 ) and the Helix/LT has recovered the reason ! I did not know all repair procedures because the instructions for use of the Helix/LT is not complete ( Version 2.10 ). Line 6 should make the effort to update its documentation because since 2016 the material has evolved. I don’t know how to thank you for your help. I appreciated your competence. Best regards Mike Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 25, 2020 Share Posted April 25, 2020 You’re welcome. Glad you got it sorted out. Quote Link to comment Share on other sites More sharing options...
