aholland
How do I turn off all touch selection in 2.9.1?
In 2.7 > in Global Settings > Footswitches - the first selection was Touch Select. The user had the option to turn it on or off.
 It seems that in 2.9.1, that became Stomp Select with  - Off, Touch, Press and Touch & Press.  I turned it to Off.  I am still getting messages asking if I want to swap snapshots.
I want to turn off ALL touch select in 2.9.1.  Does anyone know how to do that?
Thank You
Adam
Well, IIRC, it used to be that you would go to the Global Settings -> Footswitches and then set Touch Select to “Off”.
You are saying this is no longer the case. Mmm... If that has changed, I’m not aware of it and I’m not near my Helix at the moment so I’m unable to verify that.
Most odd.
Correct. The Global Settings Footswitch area has changed.  I'm sure the Touch Select is somewhere in here.....I just need to find it  :-0  ha
Thanks
Adam
I can confirm that adjusting the setting to off only disables the touch to select, aka short touch.  But the touch feature is still enabled with a long touch.  Must be a bug.
Thank you for the info.
So how does one report a bug to Line 6?
Be safe and thanks
Adam
There is an appropriately titled sticky at the top of this forum where you can report bugs.
Be safe and thanks
Adam
Hi Adam,
It may be best to open a ticket with Line 6 Support, at least that way they will have been made aware of an issue. They can investigate if this is a problem with software or hardware.
There is the “Sticky Thread” for bug reports at the top of this page, but there is no guarantee that anyone from Line 6 will see or read it. It mainly an area where users can post things they have found that could be confirmed by fellow users before raising a ticket with CS.
Good luck and stay safe.
I can also confirm that this must be a "bug".  Thanks for taking the time to formally report.  I'll be watching this closely.
