cruisinon2 Posted June 23, 2021 Share Posted June 23, 2021 11 hours ago, oktronic said: Hi, is there any timeline on when this will be fixed? I can't launch hxedit or hx native with an sd card and I need the sd card for samples on it, so removing it isn't really an option. Line 6 doesn't do "timelines" for anything... could be anywhere from 5 minutes to never. If I were you, I'd try the work-around suggested above... otherwise it could be a loooooong wait for a train that ain't coming. Quote Link to comment Share on other sites More sharing options...
oktronic Posted June 23, 2021 Share Posted June 23, 2021 Quote I believe you can re-insert the card after HX Edit loads as a workaround, if that helps. Thanks for the reply, unfortunately, reinserting doesn't work for me. If the card is inserted, neither edit or native work. The SD card has several 100Gbs of samples and VSTs on it so I can't use native and those at the same time in my DAW. Quote No one here is going to be able tell when or if it’s something that will be fixed I was kind of hoping the Line6 people would be monitoring their forums and respond with some sort of timeline. This thread has been going for a year, and the issue hasn't been resolved. Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 23, 2021 Share Posted June 23, 2021 1 hour ago, oktronic said: I was kind of hoping the Line6 people would be monitoring their forums and respond with some sort of timeline. This thread has been going for a year, and the issue hasn't been resolved. Hi, See the second black banner entitled “Why is Line 6 not responding???” at the top of this page - that explains why! Oh, yeah! It’s been there since 2015. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
ehkl Posted June 24, 2021 Share Posted June 24, 2021 11 hours ago, datacommando said: Hi, See the second black banner entitled “Why is Line 6 not responding???” at the top of this page - that explains why! Oh, yeah! It’s been there since 2015. Hope this helps/makes sense. Oh, I'm still getting notified. Yes, that is so ridiculous. It's not only that they don't monitor the forums, even support was officially involved and could not help! I gave up and bought another modeler. Sure, there are differences but they all have the potential to sound great. Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 24, 2021 Share Posted June 24, 2021 1 hour ago, ehkl said: I gave up and bought another modeler. Ah, well, you said you would, and now you have - I wish you good luck with your new device. Quote Link to comment Share on other sites More sharing options...
Rooster91 Posted July 8, 2021 Share Posted July 8, 2021 On 1/23/2021 at 12:04 AM, guido79 said: i dont know if this might help anyone but... I followed all above lines, then desperation led me to win10 control panel and then in Bluetooth and other devices. I removed all old stuff i had and then HX edit started. I had connected once my tv to the pc, an xbox and a USB storage device. Hope this can help Wow, that did help. Thank you so much!! By the way: This is still an issue with version 3.11! Quote Link to comment Share on other sites More sharing options...
afc1903 Posted August 14, 2021 Share Posted August 14, 2021 On 11/16/2020 at 10:51 AM, AlbertWoods94 said: Hi guys, first post here, just want to let you know that I had the same issue and after removing my camera SD, Helix Edit worked immediatly. Thanks for the help. Have had exactly the same problem today , and tried reinstalling HXEdit a couple of times but nothing happening - removed an sd card from the pc and problem solved. Quote Link to comment Share on other sites More sharing options...
Oldjock55 Posted October 2, 2021 Share Posted October 2, 2021 On 1/31/2021 at 6:18 PM, partydowndj said: So I have been having this issue for quite some time now, read through all the over complicated computer expert recommendations until I saw this simple rec.... solution: take out any SD card you might have in the Surface Pro's built-in reader. My best guess is if you have any PC with a touch screen, the SD card is the problem. I can't believe how many full uninstalls and crap I tried on my HP ENVY20 touch screen until I pulled out the SD card and eureka! My Power cab edit worked fine, my Variax apps worked fine as well as the updater app, but never HX edit.... On my non-touch screen PC same Windows10 operating system, HX edit and everything else worked fine. KISS (Keep it simple stupid) worked for me. Unbelievable, I worked on this for hours. So simple, thank you!! Quote Link to comment Share on other sites More sharing options...
shawnfitzpatrick Posted July 13, 2022 Share Posted July 13, 2022 On 11/20/2020 at 5:44 AM, karolp said: maybe that's the case: if so, just remove sd card, or perhaps any external usb drive too, and then try to run the HX Edit :) I'm shocked. Fought this for days. Saw this post about removing any USB drive. Had a microSD in my Surface Pro. Removed the drive and HX Edit now opens. What the heck? Quote Link to comment Share on other sites More sharing options...
