philmandoo Posted July 22, 2020 Share Posted July 22, 2020 Hi Been enjoying my Pod Go - I use a second expression pedal when playing live to control the depth and feedback of delays. Is there any way to calibrate the expression pedal? Mine is a Line 6 pedal but it doesn't go all the way "off" if you know what mean? I can't find any info on this anywhere. Cheers Phil Quote Link to comment Share on other sites More sharing options...
NBell Posted July 22, 2020 Share Posted July 22, 2020 I Phil, If I understand correctly, it sounds like you are using the Line 6 EX1 Expression pedal which does not have a 'Toe Switch' like the built in expression pedal on POD Go, thus not being able to turn off. It sounds like you would like the ability to turn off the control from the EX1 expression pedal. To do this with your current settings; Select the delay block > press Page Right/Page Left > select Knob 1 (Bypass/Control) > use Knob 2 to select EXP1 or 2 (opposite of currently used EXP on POD Go) You will now see Position at 5% on Knob 3 and a Wait time of 300ms on Knob 5. This means that when the expression pedal is at 5% or lower, it will Bypass the effect after 300ms. Although the current settings work great, feel free to move those parameters around for your playing style. Then press the home view button to return to the preset and save. In addition to this screen, you can also use Knob 1 to select other parameters within the effect block. For example, use Knob 1 to select 'Time' and set the minimum and maximum values for the expression pedal as well as the feedback; so now with the expression pedal moving from Heel to Toe, the Time and Feedback parameters can each shift to any specified setting. Cheers! Nick Quote Link to comment Share on other sites More sharing options...
philmandoo Posted July 23, 2020 Author Share Posted July 23, 2020 Nick Thanks for your reply - my issue is when I push the expression pedal all the way down when looking on the pod go editor it doesn't go to the down position but bottoms out at about 15%. Full forward is correct, but full back isn't all the way home. So if I set mix to 0% when all the way back the pedal never reaches 0, more like%. So can I calibrate the pedal to establish the range that the Pod Go recognises or do I need to find an expression pedal with a pot on the side to tweak the range? Cheers Phil Quote Link to comment Share on other sites More sharing options...
voxman55 Posted July 23, 2020 Share Posted July 23, 2020 Put the pedal fully down, then set the Pod Go level to 100% (if it's not already there), then ditto for the heel back position, set to 0% (or vice-a-versa if you prefer). Then save the patch and it should give you the desired result. If you want to set ranges between 0-100% you do the same thing but set the parameter each end to what you want - great for controlling eg amp or distortion gain eg 15% to 85% (you can even set this with or without a simultaneous volume drop via the expression pedal assignments). Quote Link to comment Share on other sites More sharing options...
tribal5000 Posted August 17, 2020 Share Posted August 17, 2020 can you calibrate toe switch sensitivity? someone please help Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 17, 2020 Share Posted August 17, 2020 15 minutes ago, tribal5000 said: can you calibrate toe switch sensitivity? someone please help There’s no such function, no. What sort of issue are you having? Quote Link to comment Share on other sites More sharing options...
tribal5000 Posted August 17, 2020 Share Posted August 17, 2020 i could of swore that when i got my pod go it had a way to calibrate toe switch sensitivity i updated to new firmware today but i dont think that has anything to do with my problem . but i cant get my exp pedal value to 0 when heel down unless i press real hard i think i need to cut a little off the rubber bumper i dont know Quote Link to comment Share on other sites More sharing options...
tribal5000 Posted August 17, 2020 Share Posted August 17, 2020 the exp toe switch works fine my problem is with the heel bumper not going to zero value the rubber bumper randomly pushes my value back up to a random value between 15/21 but am i crazy in thinking that there is a expression pedal calibration menue? Quote Link to comment Share on other sites More sharing options...
tribal5000 Posted August 17, 2020 Share Posted August 17, 2020 i think that you use to be able to hold navigation right button while powering on the unit and that would bring you to diffrent menues one being expression pedal calibration now it brings you to a pure white blank screen? i dont know ...........line 6 please fix this Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 17, 2020 Share Posted August 17, 2020 12 hours ago, tribal5000 said: i think that you use to be able to hold navigation right button while powering on the unit and that would bring you to diffrent menues one being expression pedal calibration now it brings you to a pure white blank screen? i dont know ...........line 6 please fix this That might be a hardware test mode. I'm pretty sure there isn't a calibration page, as the pedal should auto-calibrate whenever you power cycle. Quote Link to comment Share on other sites More sharing options...
wanshai09 Posted December 30, 2021 Share Posted December 30, 2021 It has the same problem with my expression pedal, 25% pedal seems not working it has still the loud volume in it Quote Link to comment Share on other sites More sharing options...
wbr67 Posted July 18, 2022 Share Posted July 18, 2022 Line6, can we get a definitive solution on how to calibrate the POD GO built-in expression pedal? My unit covers the entire range from 0% to 100% in the MIDDLE THIRD of the physical pedal position. In other words, I'm at 0% with the pedal all the way back. As I move the pedal forward, it stays at 0% until I'm 1/3 of the way through the full pedal throw. Then it climbs from 1%, and I hit 100% at 2/3 forward, where it stays until all the way full forward. The sensor for the expression pedal is an optical IR emitter/sensor pair (not a mechanical potentiometer). The emitter/sensor pair sit side-by-side facing a small shiny metal plate attached to the underside of the pedal. When the pedal moves, the shiny plate changes the angle of reflection of the emitted IR light, in turn changing the amount of light reaching the IR sensor. A nice design with no moving electrical parts. BUT, there must be a way to calibrate this system, as the amount of light reaching the sensor will vary depending on several things not related to the position of the pedal: 1. The reflectivity of the shiny plate will vary depending on exact installation angle, accumulated dust, and age. 2. The amount of IR emitted will vary by LED. Even the tightest tolerances have variations. 3. The amount of IR received will vary by sensor. Even the tightest tolerances have variations. Pics attached, just for reference. The extra chip on the left in two of the pics is a replacement emitter that I was installing, since the stock emitter in my POD GO failed during an outdoor gig on a hot day. The replacement emitter works great, but it needs calibrating. Quote Link to comment Share on other sites More sharing options...
Michaelsteve Posted July 25, 2022 Share Posted July 25, 2022 Where did you get the emitter? I might need one. Quote Link to comment Share on other sites More sharing options...
