Connecting Cry Baby Wah to HX Stomp
ATGraham93
Hi, I am having issues connecting my Dunlop Cry Baby Wah to my HX Stomp. I have seen that this can be done, but I might be missing something. When I connect the Cry Baby directly to the Stomp, and try to assign the Wah block to the expression/FS, it doesn’t seem to work. Anyone know if this is something that can be done? I am new to connecting additional pedals to my Stomp, so I might be missing something.
Thank you!
The Crybaby won’t work as an expression pedal for the Stomp. You could use it as a regular wash pedal by just putting it in between your guitar and the Stomp’s Guitar In if you like, though.
Thank you!
As Phil said, a wah pedal cannot function as an expression pedal... they are fundamentally different devices. And just to elaborate, if you choose to use the Cry Baby in front of the Stomp, get rid of the wah block from your signal chain... it won't do anything but use up DSP. Minus an expression pedal, you cannot use the Stomp's wah effects.
  • 7 months later...
I did that. If you put in front of the helix it makes a loud noise. If you put it after there is no noise. I would like to put it somewhere in the middle of the effect chain. Does anybody know how
Do you know how to assign the wah pedal somewhere in the middle of the effect chain? Thanks.
I just made my wah pedal work within the effect chain. I added a looper block. Then I connected the wah this way. > SEND to wah input. >Wah output to RETURN Mono. It worked. My Wah is A Joyo Wah II. Wah and volume pedal. (The 4CM methods prests that comes with Helix already has the block
If you're putting an external wah in the effects loop, then you can insert the loop anywhere you want in the signal chain... though why you'd want it anywhere but first is beyond me. Wah pedals expect a raw, instrument level guitar signal. If you start feeding it a signal that's already been processed in various ways with an amp model, distortion fx, etc, it's just gonna sound weird.
And, if you're just gonna be placing the fx loop first in the chain anyway, it begs the question,  why bother using the effects loop in the first place? You're just using up DSP for no reason. Just plug the guitar into your wah, and then go straight into the input on the Stomp.
Quote
You're making this harder than it needs to be... see above.
Cruisinon2 is correct about general preferred placement for a wah and the potential benefits of not using the effects loop on the Stomp in this case if you don't have to.  It might be worth figuring out why you are getting noise when placing the wah before the HX Stomp. Short of a defective wah pedal it could be a cable, battery, power supply or outlet, Input block level(Line, Instrument) on the HX Stomp, or even unshielded electronics on the guitar. Sounds like you have an alternative in place though should you need it.
