Wn564633711 Posted November 10, 2020 Share Posted November 10, 2020 Hello, line6 team. I am a POD GO user, I have a suggestion: I can freely delete the blocks in the effect chain (instead of closing). I hope you can add this function through firmware update. The tone of POD GO is great. But it is very inflexible. Because POD GO's amp/preamp, cab/IR, Wah, Volume pedal, Preset EQ, and FX Loop always exist, and they can only be turned off and cannot be deleted. This means there are only 4 places to place other blocks. For me, I don't need cab/IR, Wah, Volume pedal, FX Loop. I need to use compression, boost, noise gate, delay, and reverb blocks (5 in total). But there are only 4 positions, which cannot meet my needs at all. Therefore, I hope that blocks in the effect chain can be freely deleted (instead of closing). I hope you can add this feature through firmware update. I believe that most POD GO users have this need like me. Looking forward to your reply. 中文原文: line6团队,你们好。 我是一位POD GO用户,我提一个建议:我可以自由删除效果链中的模块(不是关闭)。希望你们能够通过固件更新,添加此功能 POD GO的音色很棒。但是很不灵活。 因为POD GO的箱头模拟、箱体模拟、蛙音、音量踏板、预设EQ、FX LOOP始终是存在的,并且只能关闭,不能删除。这意味着只有4个位置来放置其他模块。 对于我来说,我不需要箱体模拟、蛙音、音量踏板、FX LOOP。 我需要额外使用压缩、激励、降噪、延迟、混响模块(总共5个)。但是只 有4个位置,这根本无法满足我的需要。 因此,我希望可以自由删除效果链中的模块(不是关闭)。希望你们能够通过固件更新,添加此功能。 我相信,大部分POD GO用户和我一样,都有这个需要。 期待你们的回复。 Quote Link to comment Share on other sites More sharing options...
grdGo33 Posted November 10, 2020 Share Posted November 10, 2020 Line6 does not appear to read this forum. But yeah there are many threads like this asking for more flexibility, Line6 has never answered any of them. I don't think I've actually seen a Line6 answer to any topic anywhere... 1 Quote Link to comment Share on other sites More sharing options...
scotterp Posted November 11, 2020 Share Posted November 11, 2020 This is a user community forum. There is a place for product suggestions that Line 6 does check. It's called Ideascale. Go to line6.ideascale.com and register. Quote Link to comment Share on other sites More sharing options...
cristt Posted November 12, 2020 Share Posted November 12, 2020 All of the above is correct, but apart from line6 reading this forum or not, the request for deleting won't be take in consideration anyway I guess. First, there's no point in "deleting" blocks, like you cannot delete presets, it's not inherent from a computational point of view. And if you mean "deleting" in order to free up space for adding blocks or blocks types, well, this is a Pod, and it's quite cheap, for a reason. If they'd allowed more freedom (i.e. a second DSP) the cost would had levitate and it would have been an helix series efx, not a pod. The design of this machine is meant to be simple. If you feel like being limited by the pod go, maybe it's not the gear for you, and you should aim from a helix stomp or another hx series unit. 2 Quote Link to comment Share on other sites More sharing options...
