DSP load display
ruperthawkes
I'm not sure what you mean by "for each DSP" but I'm assuming you mean DSP for each block.  There are some documents squirreled away on here that give some rough estimates of DSP usage for each type of block, but that's all I've ever seen.  You might want to look on IdeaScale and see if someone has put something like that in as a feature request and vote for it.
Wrong forum. This is where you go if you're serious about suggestions for changes and improvements:
https://line6.ideascale.com/a/index
Before posting a new idea, please search to see if it's already been proposed. If 100 people vote on the same idea presented 20 different ways, it looks like only 5 people care about it!
Also, post your ideas one at a time. I for one NEVER vote for multple combined suggestions.
7 hours ago, ruperthawkes said:
Would be nice if they added a display of the DSP load of each DSP for the Rack.
As mentioned by “rd2rk” you need to post a request in Ideascale and see if others vote for it.
Meanwhile, if you want to have a better idea of what amps and effects are guzzling in DSP you should check this - forum user Malhavok’s (Ben Vesco) listing of DSP allocation in Helix.
https://benvesco.com/store/helix-dsp-allocations/
Hope this helps/makes sense
