djillard Posted February 17, 2014 Share Posted February 17, 2014 Okay,what I have is a pod hd500 and dt 50 212,I really like the looper function of the pod,If only it lasted for a longer period of time.Iv'e been looking at the Jm4 looper ,would I be able to place it in line with the pod and amp and get the play along and record features of the jm4 Thanks Dave Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted February 17, 2014 Share Posted February 17, 2014 You could put the looper into the FX loop of the HD or the DT. If using in the loop of the HD, put the FX loop block last in your signal chain. A sidenote pertaining to the HD500 looper: -set it to half speed before you start the loop and you will get twice the length of loop time Quote Link to comment Share on other sites More sharing options...
phil_m Posted February 17, 2014 Share Posted February 17, 2014 What are you hoping to do with the looper? The JM4 does a lot more than just looping. It gives you the ability to play backing tracks, and it has on-board amp modeling and effects. If you don't need all those options, there are less expensive options available to you. Quote Link to comment Share on other sites More sharing options...
djillard Posted February 17, 2014 Author Share Posted February 17, 2014 Thanks so much for the replies,What I really want to be able to do is record a track and have it play back through the amp so that I can play along with it.Now as far as the amp modeling and fx go I think the pod has that covered but I like the idea of being able to play backing tracks.And I would like to stay with line 6 equip. Thanks Dave Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted February 17, 2014 Share Posted February 17, 2014 the JM4 is basically a foot pedal version of the spider jam amp. i don't think it will work like you want it to. I have done a similar thing with my Boss RC300... but that may be overkill for what you're trying to do. Quote Link to comment Share on other sites More sharing options...
stephenhunt12 Posted August 29, 2016 Share Posted August 29, 2016 Hi I have a line 6 JM4 Looper. Is it possible to use this with my Line 6 112 Spider valve amp? I have tried it connecting to the 'preamp in' socket but the noisy hum level renders it useless for live work. The looper works fine with a fender practice amp. Quote Link to comment Share on other sites More sharing options...
