Agamemnon5
Pod GO vs Helix HX
Im not sure which one of these to get, i don't really care about amp sims etc just fx, the Go has an expression pedal, looks better(I know i know lol) So im leaning towards that but im assuming the HX sounds would be higher quality, not so sure. Any help?
Thanks
Well, the effects are the same with a few caveats. The POD Go doesn’t have a few models the HX Effects has - the Cosmos Echo and Tone Sovereign (King of Tone) and to name a few. It also won’t be getting the new polyphonic effects coming with the 3.0 update. The POD Go delays have a max delay time of 2 seconds, whereas the HX Effects delays max out at 8 seconds.
Really, if you’re genuinely not interested in amp models, the HX Effects is the way to go. It will give you a lot more flexibility, and it’s a lot more powerful as an effects-only platform.
How are the amp sims? i say i don't want them but they might be useful for getting djent style sounds, i know many djent bands like line 6, it is not my main aim but could be useful, mostly i just want fx though.
I quote phili_m
the amp sims are the same of the helix series (except some missing if I remember) so top line 6 quality. you also can load IRs.
37 minutes ago, cristt said:
I quote phili_m
Pod Go has all the current Helix amp & cab models. There are currently only 3 Helix FX not in Pod Go:  Clawthorn drive, Distortion > Tone Sovereign, Delay > Cosmos Echo
you sure? I knew at least one or two amps are not there. if I go wrong, good to know.
Have a look at the amp models listed in the Pod Go manual and then compare with the Helix manual. If you see any differences, please do flag them.
Is it possible to disable both amp and cab sims? I don't know if i should do the 4 cable method or just run in to my effects loop, im thinking i should do the 4 cable method so i can use boosters/overdrive pedals to drive the preamp i think.
Thanks
Yes, like any block, the amp block and the cabinet block can be disabled.
Take a look at the "POD Go FAQ" topic. Every HX amp / cab are included.
Thanks!
I've just looked on the BenVesco DSP chart and there are some further effects that are in Helix but not in Pod Go. I think there are 5:
clawthorne drive    Wounded Paw Battering Ram bass overdrive (Hx DSP allocation 17.87% mono, 34.33% stereo)
cosmos echo    Roland® RE-201 Space Echo  (Hx DSP allocation 14.13% mono,  25.6% stereo )
tone sovereign    Analogman King of Tone V4 (Hx DSP allocation 20% mono, 38% stereo)
Legendary Drive    Carvin VLD1 Legacy Drive (high gain channel) (Hx DSP allocation 21.33% mono, 41.33% stereo)
3 osc synth    Line 6 Original (Hx DSP allocation  8.97% mono, 18.13% stereo)
I'm not quite sure why the 3 Osc Snth wasn't included in Pod Go as based on the Helix DSP useage it would use up less DSP than the dual pitch, which is included in Pod Go
According to the FAQ, it's because this effect exists only in stereo, and the POD Go only includes mono version of Pitch/Synth effects.
So i have decided to get a helix hx but im unsure how to connect it up, i want to use it for things like reverb, chorus etc etc in my amps fx loop, while using a maxon od808 as my OD, sorry for the silly question im just a bit confused.To someone who has tried in fx loop for these types of effects or in front of amp which would you say is best?
Does it just go like this
Guitar into Maxon OD into amp input
Send of amp to return of hx
Send of hx to return amplifier
or should i use the 4CM and do this
Guitar to HX Effects Guitar In
HX Effects Send Loop 1 to Maxon OD to Amp Main Input
Amp FX Send Loop to HX Effects Return Loop 1
HX Effects 1/4" Left (mono) Out to Amp FX Return Loop
Thanks
Hi @Agamemnon5If you have queries on Hx bear in mind that as this part of the board is for Pod Go, you need to ask Hx queries on the Hx forum.
