DugT Posted December 6, 2020 Share Posted December 6, 2020 For bedroom playing, will the Helix output work with the input of a good full size Yamaha stereo receiver? I would only play at lower volumes and only a few times a year. I don't want to take my frfr back and forth to my other house. Quote Link to comment Share on other sites More sharing options...
datacommando Posted December 6, 2020 Share Posted December 6, 2020 1 minute ago, DugT said: For bedroom playing, will the Helix output work with the input of a good full size Yamaha stereo receiver? I would only play at lower volumes and only a few times a year. I don't want to take my frfr back and forth to my other house. Hi, Possibly you would be better off using some good quality headphones that would give you better results - tools to do the job. Lots of options at various price points - discussed many times on this and other forums - do a search. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
DBCrocky Posted December 6, 2020 Share Posted December 6, 2020 It will work. Be sure to set your output to line level. Quote Link to comment Share on other sites More sharing options...
DugT Posted December 6, 2020 Author Share Posted December 6, 2020 Thanks for the replies! I did a search and it looks like using the TRS (Stereo) mic output and a cable like the one below would be a good way to do it. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 6, 2020 Share Posted December 6, 2020 As long as it's a Line Input, a normal dual 1/4" to dual RCA will be fine. Also, the regular 1/4" Outputs (set to LINE) will probably work best. There is no mic output, you probably meant Headphone, which may also work, but if you already have a TS to RCA cable, no need to buy an Insert Cable. Quote Link to comment Share on other sites More sharing options...
DugT Posted December 6, 2020 Author Share Posted December 6, 2020 3 hours ago, rd2rk said: As long as it's a Line Input, a normal dual 1/4" to dual RCA will be fine. Also, the regular 1/4" Outputs (set to LINE) will probably work best. There is no mic output, you probably meant Headphone, which may also work, but if you already have a TS to RCA cable, no need to buy an Insert Cable. Thank you. Yes, I did mean headphone output. I was going to use one TRS cable and output from the headphone because that seemed like the simplist way to play in stereo but now I see that the Headphone output cannot be set to line. I will get two TS to RCA cables as you suggested. Quote Link to comment Share on other sites More sharing options...
