terry Posted March 24, 2021 Share Posted March 24, 2021 Updated HX Stomp firmware today after quite a while of inactivity. Now for some reason buttons Home/view and back page not working. Cant get into menu/global/mode settings etc from unit. Everything works fine using HX Edit. Tried the obvious rolling back to previous firmware/global reset etc without any luck. Anyone having a solve would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 24, 2021 Share Posted March 24, 2021 Re-install HX Edit 3.01. Reinstall v3.01 FW. If it still doesn't work do a factory reset. 1 Quote Link to comment Share on other sites More sharing options...
terry Posted March 24, 2021 Author Share Posted March 24, 2021 Hi rd2rk. Yep, did all those plus a full preset/patch ir reset, even tried every previous firmware version, still nothing from those two buttons. Dumfounded as each firmware install proceeds and completes 100%. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 25, 2021 Share Posted March 25, 2021 Sounds like time to open a support ticket. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted March 29, 2021 Share Posted March 29, 2021 On 3/24/2021 at 10:14 AM, terry said: Updated HX Stomp firmware today after quite a while of inactivity. Now for some reason buttons Home/view and back page not working. Cant get into menu/global/mode settings etc from unit. Everything works fine using HX Edit. Tried the obvious rolling back to previous firmware/global reset etc without any luck. Anyone having a solve would be greatly appreciated. If this happened on my Helix the first thing I would check is using the Global reset options to put the Helix in test mode(FS 3&4 on the Helix) which does a low level check of the hardware and allows you to test all the buttons and switches. I don't see a test mode global reset option listed for the Stomp though. Just mention it in case one exists and isn't listed yet. On 3/24/2021 at 8:10 PM, rd2rk said: Sounds like time to open a support ticket. Short of finding a test mode that allows you to test those buttons and given the fact that you already tried rd2rk's other remedies a ticket does sound like your next step. Who knows, maybe Line6 has a test mode you can try. Quote Link to comment Share on other sites More sharing options...
