JogNeuch Posted March 26, 2021 Share Posted March 26, 2021 Hello all, I have an Hx Stomp with the Mission Pedal and I have a problem I couldn't solve : I have a wah block and a volume block (see configuration hereafter) Everything works perfectly except the volume is 0 at startup. I first have to move the pedal to the heel position (still no sound) and only when I move it to the toe direction the sound start to increase. Is there a way the the stomp "reads" the actual value of the EXP pedal at startup ? Do I have a wrong configuration ? Thank you. Firmware 3.01 Global settings : Preferences : Exp1 : EXP/FSTip FS5 : EXP/FSRing Tip Polarity : Normal Ring polarity : Normal Footswitches : FS5Fonction : ToggleEXP EXP Pedals : Exp1 position : Global Exp 2 position : Global Volume block : Position : EXP1 Bypass : none Wah block : Position : EXP2 Bypass : Footswitch 5 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 27, 2021 Share Posted March 27, 2021 From the manual page54: Global Settings>Exp Pedal Position Determines whether each expression pedal position is recalled per snapshot, per preset, or applied globally. If you want a Volume Pedal or Wah to maintain its position when switching presets, set this to “Global.” Quote Link to comment Share on other sites More sharing options...
JogNeuch Posted March 27, 2021 Author Share Posted March 27, 2021 4 hours ago, rd2rk said: From the manual page54: Global Settings>Exp Pedal Position Determines whether each expression pedal position is recalled per snapshot, per preset, or applied globally. If you want a Volume Pedal or Wah to maintain its position when switching presets, set this to “Global.” It is already set to global (see my configuration in first post). That is what I first checked. Quote Link to comment Share on other sites More sharing options...
JogNeuch Posted April 2, 2021 Author Share Posted April 2, 2021 Help, Do someone have a solution ? Is my Mission expression pedal not working, is the stomp not working ? Is it a bad configuration ? BR Quote Link to comment Share on other sites More sharing options...
JackRabbit160 Posted April 2, 2021 Share Posted April 2, 2021 Certainly not looking to hijack the thread, but I face a similar issue, albeit with a HX Effects. Would definitely like to find a resolution, and as per OP I've been through all the settings I can logically find related to the pedal and Global Settings. It's something that used to work in earlier firmware revisions, but I admit I'm not sure when (or even if) this changed in more recent iterations. Regards Jack Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 2, 2021 Share Posted April 2, 2021 On 3/26/2021 at 11:25 PM, JogNeuch said: Everything works perfectly except the volume is 0 at startup. Hi, You mentioned a Mission pedal, which I don’t use, but there is mention of a Mission pedal that uses a toe switch which even when set in the Globals, still returns to zero. Not sure if this is the issue you are experiencing- check near the end of this thread - post from “line6ujevn”. https://line6.com/support/topic/19373-switching-wah-on-off/?tab=comments#comment-378310 Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
